what afr for max power on LS6
Old Sep 17, 2002 | 08:47 PM
Dave F's Avatar
Default what afr for max power on LS6
On a wide band sensor, is around 13.2 (or 13.5 etc) the best on an LS1? Hope to get on a dyno soon, and don't want to go to lean during my experiments.
Thanks!
Old Sep 18, 2002 | 01:20 AM
DenzSS's Avatar
Default Re: what afr for max power on LS6
Shoot for 12.8 to 13.2.
Old Sep 18, 2002 | 06:03 AM
PewterZ28's Avatar
I always forget, will a car run leaner or richer on the street compared to on the dyno?
Derrick
Old Sep 18, 2002 | 04:30 PM
NoGo's Avatar
The car will run leaner on the street, so don't go too nuts on the dyno.
Old Sep 18, 2002 | 10:17 PM
DenzSS's Avatar
Yip, you lean out on the street. Generally only .1 - .2. Just aim for 13.0 and you'll be fine.
Old Sep 19, 2002 | 11:16 AM
1slowCamaro's Avatar
After you get your wideband reading how do you adjust your A/F in ls1edit? Do you change the stoich setpoint?
Old Sep 19, 2002 | 02:28 PM
NoGo's Avatar
A/F ratio at WOT is adjusted by adjusting the PE tables.
The MAF transfer function or Injector Delivery tables can be adjusted as well, but these adjustments will monkey with your part-throttle conditions as well.
Old Sep 23, 2002 | 09:17 PM
Dave F's Avatar
I run dual 4" air lines from the nose of the car directly into the airbox. This, combined with 165mph speeds on track, will definitely lean the car out. I plan on making sure the dyno shop has lots of air-flow to simulate the track, but I will keep it a little rich to be safe.
Thanks for the help!
Dave Farmer
#35 SPEED GT Corvette
