IAC too low?
Should I make the hole smaller (jb weld, rivet, etc) and get my IAC's to ~ 30? What are the 'symptoms' or problems of having the IAC too low?
If the car is running fine, don't mess with anything. IAC of zero is a problem and low single digits might be a minor problem. While I try to stay at 20 or higher, if things are good and you stay at 10 or higher I wouldn't worry about it.
