For those of you with HPTuners...
Old Jan 30, 2006 | 12:01 PM
Fran D's Avatar
Default For those of you with HPTuners...
...and are logging Dynamic Cylinder Airflow. Is this an actual parameter from the PCM or is it a calculated value within the HPTuner scan software? I can't seem to find a similar parameter in other scanning software. Surprisingly, a search on this website and others has produced no useful results.
Can anyone offer any insight?
Old Jan 30, 2006 | 12:10 PM
MeentSS02's Avatar
Kleeborp the Moderator™
I'm going to guess it is an actual parameter in the PCM since the timing table (and others) are referenced against g/cyl. Not sure what goes into the calculation though...
Old Jan 30, 2006 | 12:13 PM
Magnus's Avatar
LS1TECH Sponsor
When you right click the table display to insert parameters, it will list all the parameters available to you in nice groupings.
Near the bottom of the PID list you will see: User Defined.
This group has all the user defined "calculated" PID's that are pre-defined or created by you.
Calculated Cyl Air is a user defined PID but Dynamic Cylinder Air is not.
You can use Dynamic Cyl Air to log your g/cyl if your MAF is disconneted (or you are not logging MAF).
The calc cyl air PID will use your MAF to calculate a cyl/air value.
Old Jan 30, 2006 | 12:26 PM
HumpinSS's Avatar
What other software are you referring to if its EFILive the parameters name is GM.DYNCYLAIR_DMA and its under the System ---->> Tune on the drop down pid list. THere is one for SD and one for MAF operation.
Dynamic air is GM>DYN_AIR and that is located under the System --->>> Air
Old Jan 30, 2006 | 12:30 PM
Fran D's Avatar
Ah! That was the one website that I was unable to get on (kept getting some kind of server overload failure), but that answers my question explicitly. With the GM. prefix of the PID, I can see the this is part of the GM Enhanced message set, correct?
Old Jan 30, 2006 | 12:38 PM
Fran D's Avatar
...THere is one for SD and one for MAF operation.
Just as a follow-up, why would there be two? I can't see how being in either SD or MAF would change what one would measure as dynamic airflow. Can you elaborate?
Old Jan 30, 2006 | 12:44 PM
HumpinSS's Avatar
The maf pid most likely uses data from the maf to calculate cylinder air where the sd pid is using the ve table to come up with the air value
The main site is down fo upgrade but the forums are still up
www.efilive.com/forum
Old Jan 30, 2006 | 01:19 PM
MeentSS02's Avatar
It sounds like both are just "made up" values...I mean, not really, but if they are both referencing tables to come up with a value, then they would only be as good as the table calibration.
Old Jan 30, 2006 | 01:51 PM
Fran D's Avatar
Well, that certainly seems to be the case. Which begs the original question as to whether it is calculated in the PCM and reported as a message or whether it is calculated in the scanner software from other parameters described by the PID.
Old Jan 30, 2006 | 01:55 PM
HumpinSS's Avatar
The DMA denotes direct memory access so no that is what the PCM sees and uses not what the scanner calculates and tells the user. The computer still needs to figure out air someway somehow or it wouldnt know how and when to time the engine since the spark tables are indexed by air...
MeentSS02's Avatar
Well, as I said above, there are a few tables that are referenced against g/cyl, so it has to have some way of knowing this.
Old Jan 30, 2006 | 06:16 PM
Fran D's Avatar
OK, so what I gather by this, and your previous post (re., MAF & SD PIDs), is the dynamic cylinder airflow is not a measured parameter, but the lookup table that either the MAF (i.e., frequency vs. gms/sec) or the SD (VE vs. RPM vs. MAP) PIDs are referenced to. Correct?
Old Feb 2, 2006 | 07:42 AM
Fran D's Avatar
Any confirmation of the above available?
Old Feb 2, 2006 | 07:58 AM
P Mack's Avatar
From what I understand, it is the MAF reading corrected for the speed density calcs. It filters both inputs to come up with a number.
Old Feb 2, 2006 | 09:02 AM
Fran D's Avatar
Is this "correction" algorithm understood? As, if this were indeed the case, would it not obviate the whole SD vs. MAF controversy?
Old Feb 2, 2006 | 06:29 PM
P Mack's Avatar
What controversy are you talking about? Some people choose SD, some people don't.
http://www.hptuners.com/forum/showthread.php?t=2359
