What #s are you seeing for lbs of airflow..
all of these are at 6000rpm:
stock 01 with LM and lid did 35-36lb/min
my z06 cam'med car did 39lb/min
tr224 on stock headers did 35-36lb/min
same tr224 on LT's did 38lb/min
228/.575 mac mids did 41lb/min
F13 on LT's did 44lb/min
all forged huge cam 347, 90/90 with everything, 52lb/min
383 on ls6 intake did 63lb/min
and for fun: STS w/ T67Q on 4.5psi maxed out the MAF readings by 4800rpm
Temperature has a huge effect on what the MAF sees as lbs/min.
Colder air is much heavier.
Knowing Lb/min values without knowing the air temp they were tested at doesn't mean a great deal.
Phil
Originally Posted by RedHardSupra
it is derived, that's why it has no limits on final value, and that's a good thing
you might not believe it, but the engine does, so i would take its 'word' for the correctness of it.
Phil
Kleeborp the Moderator™
There is definitely a correlation between this value and your engine's output, but I'd really like to know how it is derived.
I certainly wouldn't consider my car a freak by any means...and I certainly don't think my numbers mean I could run with a cammed or h/c car.
I had been thinking you guys were talking of actual measured values. My own opinion of a derived value like that is that it's pretty much worthless no matter how it was derived. A derived method would have to assume too many things and would be subject to error stacking like everything else that uses multiple inputs to derive something.
That's just me thinking. I shouldn't have posted here without knowing what you were talking about.
