Knock sensor Question
Old Oct 15, 2002 | 09:44 PM
GMC SKI's Avatar
Default Knock sensor Question
Well we were out tuning the truck the other Day on the street. With 4 more degrees we didn 't see any knock retard . We decided to get more aggresive with the spark and raise it 8 degrees higher than stock.
with the 8 degrees over stock we heard some detonation/ pinging under hard throttle but nothing happing on the tech 2 and no retard in timing ?
this has us baffled could i have a bad knock sensor ?is there a way to test it ?
anything that i can do with ls1edit to make it more sensitve ?
jim
<small>[ October 15, 2002, 09:46 PM: Message edited by: GMC SKI ]</small>
Old Oct 17, 2002 | 08:46 AM
MIGHTYMOUSE's Avatar
Default Re: Knock sensor Question
if it's bad it should throw a code and pull 4* off the top. for ls1's anyway maybe the truck setup is different? sorry i was no help
