Switching to a 2 bar Map Sensor?
Old Feb 1, 2006 | 07:53 PM
ThaLS1KidII's Avatar
Default Switching to a 2 bar Map Sensor?
I just put a 2 bar Map Sensor on my turbo'd '98 Camaro to control my progressive meth controller.
Do I need to change anything in my tune to make up for the 2 bar map sensor or will the computer figure it out?
Or is the stock Map a 2 bar?
Old Feb 1, 2006 | 09:54 PM
NYSS Guy's Avatar
The car probably won't run. I installed my 2 bar map, and tried to get the car started before changing over the operating system to a 2 bar. The car would start, but wouldn't idle. Do you have some kind of tuning software?
Old Feb 2, 2006 | 09:02 AM
I have LS1Edit. My car starts and it runs fine it just idles kind of funny sometimes. What did you have to change in the operating system?
Old Feb 2, 2006 | 10:26 AM
Blackbird's Avatar
you replaced your stock map with the 2 bar to make your meth work????
why the heck did you do that?
you just add the 2 bar externally to control the meth system. There is a little voltage drop box to get for it and you just wire up power and ground and hook a vacum source up to it.
Old Feb 2, 2006 | 11:33 AM
That is a damn good idea. I am going to do that. My controller has the 5V output to power the map, so all I have to do is run a ground and run it in my boost line.
Old Feb 2, 2006 | 11:41 AM
Blackbird's Avatar
you got it.
do that and put that stock map back in.
your car will thank you for it
