How can I check O2 sensor with volt meter?
Thanks <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
You need it to be at operating temp and
have some exhaust running by it, to see
anything but zero volts. It has a pretty
high output impedance, so an old-style
analog VOM won't do (it messes up the
output fidelity) and the resistance
should read very high.
Just look at the volts with the car running,
should be bopping around between 0 and 1.0V
(ideally spending most of its time between
0.3 and 0.7V).
