car missing poping under load
edit: well I don't know what you mean by lost power completely.
Maybe you have a broken or loose ground wire, or you damaged one of the wires going to the starter.
like mad at idle / cruise and not show a steady voltage (that
being a sign of some electrical fault, on an LS1; you'd have to
research what an LT1 does).
If the headers greatly improved cylinder filling and peak pre-
spark pressure, you might need to decrease plug gap to get
rid of arc start problems. But also check ignition parts & wires'
integrity because failure to fire in the hole, means the spark
is looking for another way out. How is Mr. OptiSpark feeling
lately? Wires all clean and quiet, no visible arcing at night
with the motor loaded up? Do you have any means to look
for misfires etc. on the road?
