A4 tranny tune
Old Feb 7, 2006 | 04:04 PM
STALL UP's Avatar
Default A4 tranny tune
I really need help here with my tranny tune it is not shifting into 3rd gear under WOT without letting off the gas a little. I have had servo's installed and it did not fix it. I have been told by a couple tranny shops that it sounds like a tuning problem so I set Shift RPM at 6200 speed at 67mph and rev limiter at 6900 still hits. I really dont know what else to change.If there is someone that would be willing to look at my HPTuner bin file and maybe help me out I would really appreciate it. thanks for you time Phill
Old Feb 8, 2006 | 04:11 AM
81LS1Camaro's Avatar
I seem to have the same problem but mine bounces off the rev limiter in about every gear, I was told my problem was because my tune is for 3.73 rear gears and I have 3.08's. This throws off the computer making it think I am going slower than I really am, not letting the car shift. I wont know for sure if this is the case untill I get my gears installed this spring.
Old Feb 10, 2006 | 04:07 PM
John_D.'s Avatar
What table are you updating?
Old Feb 10, 2006 | 04:15 PM
LC's Avatar
LC
i had the same problem time ago.. 3/4 clutch pack was gone...
Old Feb 10, 2006 | 04:26 PM
BLUE99T/A's Avatar
Do you set the shifter to D or 3? Mine always hit the limiter in 3 but never in D. I don't know why, but it did.
Old Feb 11, 2006 | 12:08 PM
STALL UP's Avatar
the WOT shift speed to 67 mph and WOt shift rpm 6200 rev limit to 6900
Old Feb 11, 2006 | 12:10 PM
STALL UP's Avatar
It will do it if I manually shift, OD or D.
Old Feb 11, 2006 | 12:32 PM
RevGTO's Avatar
Pontiacerator
Do a search on posts by cablebandit in the auto trans forum. He has had some good success fixing this with tuning parameters that are often neglected.
Old Feb 11, 2006 | 06:01 PM
John_D.'s Avatar
In hptuners there are:
Normal and Performance tables under WOT Shift Speed (mph)
and
Normal and Performance tables under WOT Shift RPM
I always update all 4 of these.
Also there is a box for WOT Shift Enable TPS %.
What value is in that box?
What TPS % is your pcm seeing when you are at wot?
For rev limiter, it's in 3 places on the same page:
- P/N rev limit (park/neutral)
- Bad vss limit
- Cutoff RPM Vs Gear
If you haven't gotten that last one taken care of, that could be part of the problem.
Old Feb 12, 2006 | 10:36 AM
STALL UP's Avatar
and
- Bad vss limit
here are what mine look like thanks for you help
Cutoff RPM Vs Gear was set at 6700
bad vss cutoff at 6699 on at 6700
wot shift enable tps %95 disable 90
Old Feb 12, 2006 | 03:43 PM
John_D.'s Avatar
Are you scanning the car when it does this? Do you know what the reported TPS% or reported RPMS were?
The tach on the dash is slow compared to actual rpms.
If the tps is only showing 94%, that would put you in a different place in the table.
If the tranny is slipping, from fluid starvation, that will let it bounce off the limiter too.
A deeper tranny pan is supposed to help alleviate that.
Old Feb 22, 2006 | 08:13 PM
TopFlite's Avatar
Yep just got my car back today from having the 3/4 clutch pack replaced. Turned out the selector in my A4 was going out causing the clutch packs to burn up and thus bouncing the limiter everytime from the 2-3 shift. Got a new valve body, and works thanks to GM warranty and it shifts like new on the 2-3 and even 3-4!
