wideband results
I have a fjo wideband setup i use for tuning cars(on dyno and street). 14.3-14.6 at idle, 12.1-12.3 at wot-pretty rich i think for my lack of mods. On bottle on 75 shot stayed at 12.2 plus you couldnt feel the nitrous at all. step jet up to a 100 shot. went to 12.1-11.9 at wot but still cant feel nitrous come in. I am positive its sprayng. My problem is after the second outing i get a SES light -proabably because my o2 id out of the pass side manifold(for the wideband to go into). now car is about 16.3 at idle and 17.2 at part throttle!!! At wot its about 14.2. Of course i didnt spray it but would having an o2 disconnected caust this kind of lean condition???? Car seems to drive fine but definitely has lass power with this lack of fuel. Any ideas-on having o2 disconected and getting lean condition??? this is b2s1 o2. havent scanned it yet. tomorrow i will.
Sean
<small>[ December 15, 2002, 05:25 PM: Message edited by: lbz34 ]</small>
are you saying you took a O2 sensor out to put the wideband O2 in and ran the car like that,(with one sensor out)
This is not good, especially if you are spraying.
I couldn't feel a 75shot on my LT1 camaro at all either but you could feel the 100shot hit like a ****.
But back on topic the PCM uses both O2's to adjust the fuel to air and the rear O2's are just there to make sure the A/F and cats are happy. To run with one out is dangerous, the pcm can't adjust for the pass side bank at all.
I have an A-tap that we can run it on to see what SES light you are getting. I have tomorrow off too, just give me directions on where to find you or you can come up here.
Jeremy
PS a stock LS1 usually runs that rich from the factory I have see them as low as 11.7 on chris's dyno.
Sean
A-tap is here to use, it will work without hoping for anything, let me know. I don't know where your shop is or where to reach you other that this board.
J
Southwest General Tire/*** American Car Care
you can call me.
720-2137
Sean
Then you will have both front O2 sensors working for the PCM, and keep you out of limp home mode or open loop.
I think that going into one of these modes is bad for top performance and may result in a blown motor.
Thanks for the input guys.
Sean
I find the stock ls1 A/F to be a bit on the lean side at part throttle. Up until about 75% throttle or so the car will start out at 16:1 and ramp to about 14.5:1. Once you hit that magic TP point then viola 12.8:1.
I am amazed how lean GM likes to run the car. I like to set vehicles up to about 15:1 at cruise and as you get to about 75% throttle ramp the A/F to about 12.8:1 or so. I do not think my N/A can be a fair comparison to past cars i have tuned since the others were FI 4 cyls.
Just a little info for you guys.
Thanks for the suggestions
Sean
I find the stock ls1 A/F to be a bit on the lean side at part throttle ( in my opinion). Up until about 75% throttle or so the car will start out at 16:1 and ramp to about 14.5:1. Once you hit that magic TP point then viola 12.8:1.
I would guess the A/F's would be richer than this with a 10:1 v8. I like to set vehicles up to about 15:1 at cruise and as you get to about 75% throttle ramp the A/F to about 12.8:1 or so(this is usually with boost). I do not think my N/A can be a fair comparison to other cars I have tuned since the others were FI 4 cyls. I will enjoy trying to squeeze every bit of hp out of this car especially with out FI.
Sean
Their could only be two problems. Either you didn't spray any N2O, Or your AssOmeter is off <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
the A/F still does not change much at all. 12.6 to about 12.4 or so on the spray with bp about 950 or so. I hope i can "feel" the 100 shot. If not I will just sell the kit.
also you can run a lighted LED to the n20 solnoid(ground and hot) and if it lights up when you spray then its certainly letting N20 into the car <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Tim
Car only has lid, af, ported maf 00 m6.
Thanks for the help guys.
I guess its back to
KISS
Sean
