EFIlive 2bar SD?
Old Feb 12, 2006 | 11:20 AM
whitt1's Avatar
Default EFIlive 2bar SD?
Will Flashscan support 2bar SD tuning?Or do you need additional software?
Old Feb 12, 2006 | 11:21 AM
Black02SS's Avatar
Yes it is supported. All you need is a wideband and the commerical version of EFILive. PM me if you want details.
Old Feb 12, 2006 | 11:26 AM
whitt1's Avatar
I tune with HPtuners,but I'm installing a Starrperformance twinscrew supercharger and his base tune is done with EFIlive.I'm looking for an easy way to start my tuning with his base tune.
Old Feb 12, 2006 | 11:44 AM
horist's Avatar
HPT can not read EFI Custom Operating systems, so you will not be able to modify it....
Old Feb 12, 2006 | 11:55 AM
Black02SS's Avatar
Unless you purchase EFILive, you will have to start from scratch.
Old Feb 12, 2006 | 12:03 PM
whitt1's Avatar
For $849 I can by a lot of dyno time.
Old Feb 12, 2006 | 02:12 PM
foff667's Avatar
LS1TECH Sponsor
yup...you might wanna just have your tuner use hptuners with 2 bar & tune using your stuff so you can tweak on it later.
Old Feb 12, 2006 | 02:46 PM
Haans249's Avatar
Do you need commercial version to upgrade to an EFILive Custom OS? Or can the Personal Scan and Tune do this as well?
Old Feb 12, 2006 | 02:47 PM
foff667's Avatar
LS1TECH Sponsor
the commercial & tunershop versions can upgrade the OS for you...personal can tune & load the custom OS's after they are loaded initially with the commercial/tunershop version.
Old Feb 12, 2006 | 04:00 PM
TAQuickness's Avatar
This is true. For the average Joe, $850 is about 1.7 tunes paying a "pro" to do it.
I think what foff is trying to tell you is, Flashscan personal will alow you to modify calibrations only. Commercial and/or workshop are required if you want to upgrade your OS.
Send a pm to wait4me. Tell him what you want to do and he will take care of you.
Old Feb 12, 2006 | 05:26 PM
Black02SS's Avatar
Hey guys I have been told that some of the above information isn't true. Here is the deal.
FYI, Starr Performance do not use our custom O.S's!!, they STILL use the
stock GM O.S with halved Map scaling.
I can aso bet they sent that guy an Australian O.S 12225074 which will not
work on a US car correctly.....better get him to check that.
Either way, he is better off starting from scratch.
