free data logging programs? (for LT1 OBD2)
Old Feb 13, 2006 | 04:26 PM
nnolan's Avatar
Default free data logging programs? (for LT1 OBD2)
Are there any free data logging programs out there? There used to be one but it was for OBD I cars and I was wondering if there are any out there for OBD II cars. Any info or links would be great, or if you could point me in the direction of a cheap scanner that would be good too. Thanks
Old Feb 13, 2006 | 04:39 PM
horist's Avatar
None that I'm aware of... and if there were you can bet they won't read the GM Enhanced parameters like KR (Knock Retard)
EFI Live offers a scanner only option, Autotap also offers an inexpensive scanner (both support GM enhance params)
Proscan offers a cheap scanner but it doesn't support the GM enhanced parameters (if you can't log those why even bother logging... at least that's how I look at it)
however, the best long term bet is to get a full tuning suite as the big 2 now come with awesome scanners ontop of being able to tune.
see the sticky labeled:
Sticky: READ ME!!!! *****Best LS1 Tuning Software? Best Scanner? Best Handheld?****
Old Feb 14, 2006 | 12:02 PM
nnolan's Avatar
Sorry, I did read it, but I have an LT1
Old Feb 14, 2006 | 12:03 PM
horist's Avatar
oh ok... I think there is a free or relatively inexpensive LT1 scanner (though it may be OBD1 only).. I'll edit your title to see if we can get some of the more LT1 knowledgable guys in
Old Feb 14, 2006 | 12:49 PM
nnolan's Avatar
Thanks, yeah I found an outdated one but its for OBD 1 cars.
Old Feb 15, 2006 | 08:53 AM
roughneck427's Avatar
Why dont you just get a OBD1 conversion its better for tuning anyways and www.ttsdatamaster.com has some good free software i use it on my 95 you can pay $90 and get the registered version that you can record your datalogs with the free download you are able to do 20 recorded runs but as far as live data its free its also a scanner and erases DTC codes and calculates 1/4 mile and hp really good program .Another benifit with the OBD1 deal is you can get www.tunercat.com for your tuning software only $100 alot cheaper if you would go the OBD2 route.Also you would need a cable www.mastach.com has them for $40 its works great cheapest ive seen around all the others are $100 or more
Old Feb 15, 2006 | 03:00 PM
nnolan's Avatar
I already have tunercats for my OBD II car
Old Aug 11, 2010 | 04:59 PM
twin turbo 383 lt1's Avatar
hay i got a 94 camaro with a 383 lt1 with twin t72 turbos and i have the ls1 coil conversion swap with 120lb injectors is there a data logger for the ls1 ecu that i can down load i dont want it to program just to data log my engine it needs to go to 1500hp and work on e85 gas and what progranm on the cumputer do you need like windows 7 or older version thanks matt
Old Aug 11, 2010 | 10:01 PM
brucer's Avatar
if you have a 94-95 obd1 pcm, you have to buy an aldl cable,but you can download tunerproRT version5 beta for free, they also have the definition files for free also...
with tunerproRT you can datalog,monitor, and tune..
Old Jun 11, 2012 | 01:16 PM
FrawG's Avatar
Can you link a OBD2 to OBD1 Conversion? I am trying to find one of these online.
Thanks
