P0155...should I be concerned?
Thanks
Mark
I cleared the code, but should I worry about it? Once you clear a code, will it set again if the problem happens again? And then what would be the first place I should look? A new O2 sensor on that side?
Thanks
I have seen this problem on a few other SLP header cars as well.
You can try changing out the O2 sensor, but I'm pretty sure the problem will come back.
The problem stems, this is my own assumptions, from moving the O2 sensor too far back allowing the sensor to cool to much. This has generated insufficient switching codes as well as heater codes on quite a few peoples cars.
The problem seems to be particular to certain types of headers.
On cars that have generated this problem turning off the code is really the only certain method I have seen to taking car of the problem (which it really isn't doing)
Other people have tried pushing the O2 sensor farther into the exhaust, heat wrapping the headers, coating the headers.... All have had mixed results.
Good Luck,
Kevin
I've reset the code and I'll have to see if it pops up tomorrow morning. THere is a spot where the O2 wire extension is up against the header, but it has the thermal protection on it and I looked at it with a flashlight and it looked OK. Plus the O2 sensor itself is reading voltages within the normal range.
If it pops up again I'll have to check out the wires after work tomorrow. Do you think it could be the sensor itself?
Thanks
Mark
Now I am wondering if the water from the roads and the 2.5"-3" of ground clearance I have is cooling them down to less than the 600 deg they are supose to be at? Just a thought/shot in the dark!
Hope you find it, I'm still chasing my tail!
Also I know of 3 brand new cars that are having the same issue and they are 100% stock!!One just went to have a buddy do a pre-test for smog just for kicks and it FAILED!! with only 5K on the car!!
Good luck.
I drove to work today without seeing it, but I read somewhere that it takes two cycles for it to come back...have to see what happens when I go home at the end of the day.
Thanks
Mark
it set the code lastnight on a new pcm, this morning I drove to the gas station filled up started logging and it was gone!
I will se if it reapears on my trip home. I have 3 stops to make for 30-40 minn. so it should have time to cycle and set a DCT again.
