no need for MAFT or HPP3 if you use LS1 Edit?
Location: makin' late night batches of stomach pancakes
I was going to buy some mods for the car and then head down to FLP's shop this spring and have it dyno tuned using ls1 edit, is there a need to have a MAFT or use HPP3 if I am going to have this done because doesn't edit have the capabilities of doing the same things?
thanks <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Re: no need for MAFT or HPP3 if you use LS1 Edit?
That is correct.
An HPP3 would allow an A4 to set the shift points at the track for best results. IMO, the best thing is have your own copy of Edit and then get dyno tuned. That way when things change you can update your pcm.
