Idle hunt: to much timing or what??
Old Feb 3, 2003 | 09:12 PM
nitrousc5's Avatar
Default Re: Idle hunt: to much timing or what??
just for grins, did you try another 1-2 degrees of timing in your Base tables? as an experiment, try it, put some miles on it, see what yields.
the main point i am trying to make with all my input here is that you may actually need a little bit of everything at idle: more air, more fuel and more timing. sometimes people get confused about their idle symptoms when all indications suggest it should be fine. It is in this situation i have found the motor to just need a little more of everything. Just a suggestion since i am not there seeing/hearing the car and looking at your traces myself. there may be other clues uncovered.
<small>[ February 03, 2003, 09:20 PM: Message edited by: nitrousc5 ]</small>
Old Feb 3, 2003 | 10:28 PM
98TAauto's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by nitrousc5:
<strong> just for grins, did you try another 1-2 degrees of timing in your Base tables? as an experiment, try it, put some miles on it, see what yields.
the main point i am trying to make with all my input here is that you may actually need a little bit of everything at idle: more air, more fuel and more timing. sometimes people get confused about their idle symptoms when all indications suggest it should be fine. It is in this situation i have found the motor to just need a little more of everything. Just a suggestion since i am not there seeing/hearing the car and looking at your traces myself. there may be other clues uncovered. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">on atap my timing showed to be around 22-23 at idle. What table would I tweak to get a little more fuel at idle? And what cells also....
also its normal for my 02's to stay like around .850 before they reach a certain temp and then they start switching??
<small>[ February 03, 2003, 10:34 PM: Message edited by: 98TAauto ]</small>
