Idle hunt: to much timing or what??
Old Jan 27, 2003 | 04:46 PM
98TAauto's Avatar
Default Idle hunt: to much timing or what??
I got a reply in another post that my idle hunt on cold start ups may be from to much timing??
Usually when i start my car for the first time(cold) after like 20seconds the idle will hunt up and down like 100-200rpms, and then after about a minute it settles to normal idle.
I had this issue before I added 1-2 degrees of timing in the base spark park and drive tables from 400-1200rpms for the cells down to .2
Since ive added this timing warm starts have become much easier! The car doesnt stall anything like it use to before, but the cold start idle hunt is still there for like a minute or so.
LTRIMS and timing at idle are around -7 to -3, while timing is around 19-20 if that helps any
oh and I have a 224/224 .563 114 cam also
Old Jan 28, 2003 | 02:37 PM
NicD's Avatar
7 Second Club
Default Re: Idle hunt: to much timing or what??
Turning off your AIR is not going to cause a stumbling cold start. If you notice the timing doesn't actually go up at idle to the regular values in the current tables until it warms up a bit. In the new version of LS1edit that is going to be released there is another timing vs coolant temp table that could possibly be used to give it more timing on a cold start. We shall see.
Old Jan 29, 2003 | 12:16 AM
HITMANSS's Avatar
Harold, the cold start idle may be because you've deleted or blocked off your air pump --- the air in the exhaust helps your cats light off quickly. Or do you even have cats?
Old Jan 29, 2003 | 12:44 AM
98TAauto's Avatar
no cats... but you could be right I guess because I did edit off my AIR
Old Jan 30, 2003 | 08:41 PM
Cool28's Avatar
Tire Smoking Tranny Blowing Director
DOes your sometimes stall when cold when stoping or backing out? MIne has been doing it since I got my car back. I replaced my temp sensor and it helped alittle with idle hunt(same as yours)and missing. It still wants to stall when cold when I first backup. Just wondering if you have the same problems.
Old Jan 30, 2003 | 08:44 PM
GrannySShifting's Avatar
try 28 degrees of timing maybe more just for fun. you know, like a LS1 harold <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Jan 30, 2003 | 09:07 PM
98TAauto's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Cool28:
<strong> DOes your sometimes stall when cold when stoping or backing out? MIne has been doing it since I got my car back. I replaced my temp sensor and it helped alittle with idle hunt(same as yours)and missing. It still wants to stall when cold when I first backup. Just wondering if you have the same problems. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Cool: If i dont wait for that idle hunt to stop when i put her in gear the car will search for IDLE very badly and stall. If I wait for idle hunt to stop(probably 1min) and then put car in gear its fine...
but if I do anything before that idle hunt settles or stops the car will usually surge badly and stall....Ive replaced my temp sensor about 4months ago because it was broken...
<small>[ January 30, 2003, 09:16 PM: Message edited by: 98TAauto ]</small>
Old Jan 31, 2003 | 01:47 PM
gojo's Avatar
You could also try increasing your IAC's. Try 110% at a time.
Old Jan 31, 2003 | 09:33 PM
98TAauto's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by gojo:
<strong> You could also try increasing your IAC's. Try 110% at a time. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I would if they had that option avaible on the LS1 edit I have... something about this option not something for this year
<img border="0" alt="[judgement]" title="" src="graemlins/gr_judge.gif" />
Old Feb 1, 2003 | 07:04 PM
AFTICA's Avatar
98TAauto...I've been following your threads about this. Just put a B1 in my 98 A4 and had some cold & hot surging. Solved the cold surge by simply increasing the idle in the colder temperature rows, both in gear & in park. Still have an intermittant surge on hot startup even after trying your idea of 1-2* timing in the 400 -1200 tables. I agree that the iac park position probably would help us (98's)if it was enabled for our year
Old Feb 1, 2003 | 08:40 PM
98TAauto's Avatar
ahhh, so i see im not the only one that cant increase the IAC in park <img border="0" alt="[shoot]" title="" src="graemlins/gr_guns.gif" />
Im gonna try raising my park idle a tad bit more. I think its at like 1050 around 0-40 degrees now though. I went ahead and set my idle to 1000 all the way across also and that helped a tad bit. It just makes me sick seeing cam cars idling perfect around 850rpms <img border="0" alt="[judgement]" title="" src="graemlins/gr_judge.gif" />
Old Feb 2, 2003 | 08:48 AM
AFTICA's Avatar
With my B1 I set the hot idle to 775 in park & in gear. I wanted it low enough to hear the lope but high enough not to stall.Seems to be perfect. Just have to cure the intermittent hot surging. I'm sure raising the idle a bit more would do it, but I want to hear that lope. I know your cam has a bit more duration than mine, but I'm surprised you need so high of an idle to stop the surging.
I wonder if Edit is planning to release an upgrade regarding the iac park position for our 98's or if we just have to live without it.
Old Feb 2, 2003 | 05:23 PM
98TAauto's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by AFTICA:
<strong> With my B1 I set the hot idle to 775 in park & in gear. I wanted it low enough to hear the lope but high enough not to stall.Seems to be perfect. Just have to cure the intermittent hot surging. I'm sure raising the idle a bit more would do it, but I want to hear that lope. I know your cam has a bit more duration than mine, but I'm surprised you need so high of an idle to stop the surging.
I wonder if Edit is planning to release an upgrade regarding the iac park position for our 98's or if we just have to live without it. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">hopefully they will put out a update for the IAC on the 98's!! That would probably help alot. But I went about 200miles today and i think the car learned alot and got better. I did raise my idle to 1000 but on atap it settles to like 900. I didnt get a warm start stall today at all! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> I think its just hit or miss with A4's and idle. Some idle perfect with big cams, while some HATE cams LOL
Old Feb 2, 2003 | 06:40 PM
Cool28's Avatar
hmm who has a ported maf here?
Old Feb 3, 2003 | 10:32 AM
98TAauto's Avatar
I have the stock MAF... but a calibrated SLP 85mm is on order though
Old Feb 3, 2003 | 11:35 AM
nitrousc5's Avatar
if no iac table you may have to drill TB blade, then adjust the Injector Flow Rate (IFR) table to bring in more fuel at the idle speeds. You may also not have enough timing, instead of too much. Key is to experiment with one parameter at a time WITH LOTS OF RELEARN MILES in between. this is one thing i have learn with tuning idle issues. Give each tune plenty of relearn miles, even if it means putting up with hanging idle speeds at coast, intermittent stumble, etc. the long miles DO help a great deal to see what your changes will really yield.
<small>[ February 03, 2003, 09:15 PM: Message edited by: nitrousc5 ]</small>
Old Feb 3, 2003 | 01:32 PM
98TAauto's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by nitrousc5:
<strong> if no iac table you may have to drill TB blade, then adjust the Injector Fuel Constant table to bring in more fuel at the idle speeds. You may also not have enough timing, instead of too much. Key is to experiment with one parameter at a time WITH LOTS OF RELEARN MILES in between. this is one thing i have learn with tuning idle issues. Give each tune plenty of relearn miles, even if it means putting up with hanging idle speeds at coast, intermittent stumble, etc. the long miles DO help a great deal to see what your changes will really yield. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I was wondering if i may me lean at idle, but my ltrims are around -5 to -7 normally. The warm surge has definitly gotten better since I put some LONG miles on her. If I could do it all over I would have given the car atleast a week and some good miles to learn. These cars still amaze me with there learning process <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Feb 3, 2003 | 02:24 PM
98TAauto's Avatar
ok i just checked my LTRIMS while its doing that surge. They are right around 0 and -1.
Also I had the car stall on a warm start today and I had to apply some gas to get the car to finally start again.
Didnt someone say that if you have to apply the gas to get the car to start it means something?
also i noticed at the car got warmed the LTRIMS dropped to -3
Old Feb 3, 2003 | 03:34 PM
JNorris's Avatar
Moderator
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 98TAauto:
<strong> Didnt someone say that if you have to apply the gas to get the car to start it means something?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I think that it would mean that you need more air to start the car. If LS1Edit had ICA park position for the 98s your problem (and mine) would be solved.
Yesterday I raised timing in park and in drive another 1 degree for a total of 3 degrees in park and 2 degrees in drive and had NO problems with warm starts. There was still about 10s of idle hunting. I have the idle set at 875 in park and 825 in gear.
John
Old Feb 3, 2003 | 04:36 PM
98TAauto's Avatar
John.... lets pester carputing and get them to fix that <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
i cant drill the hole anymore since my IAC's are already friggin low <img border="0" alt="[judgement]" title="" src="graemlins/gr_judge.gif" />
Me and a friend did a little test on it yesterday. We turned the set screw back to stock and the car wouldnt idle or do anything since it wasnt getting enough air so we had to turn it ahead a turn again. But yet on atap when warm my IAC's are around 0-10 <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
