Still getting misfire codes
Old Feb 18, 2003 | 07:55 PM
Slowhawk's Avatar
LS1Tech Sponsor
Default Still getting misfire codes
01 Z28 M6 with ported Heads,TR224 Cam,and SLP longtubes.
Every once in a while it will throw out the p300 code.I'm getting slight misfires from all cylinders.
On Edit I raised the idle to 850rpm and set the low idle misfire test to 32000.
Any other tricks I can do?How about adding a couple deg. of timing in the idle?
P.S My own 01 TA has the same exact setup and tune but never has thrown a code.
Thanks
Old Feb 18, 2003 | 08:14 PM
jimmyblue's Avatar
Moderator
Default Re: Still getting misfire codes
I think taking out some base advance might
be a better bet for smoothing out idle.
At low speed with a big overlap cam, it
needs time to make up its mind whether
it's coming or going.
