MAFT tuning
Old Feb 19, 2003 | 06:43 AM
Wile_E's Avatar
Default MAFT tuning
I was wondering if it were possible to achieve an optimum air/fuel ratio tuning a MAFT using only an A/F gauge to measure.
Old Feb 20, 2003 | 07:26 AM
MIGHTYMOUSE's Avatar
Default Re: MAFT tuning
i hate it when nobody replies to a straight forward question of mine.. so here it is for you
for wide open tuning our oxygen sensors are not calibrated to read 'perfectly' so the %error is greater than what you would want to bet money on, that and the light gauge is really hard to pinpoint an exact voltage.. with autotap i say you have a decent tuning ability, but the gauge is mostly to just see a good or 'bad' situation.
dont get me wrong you can definitely use it and make changes in the right direction.. but not 'optimal' like you said
Old Feb 20, 2003 | 11:12 AM
Wile_E's Avatar
Thanks MIGHTYMOUSE <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Feb 21, 2003 | 02:42 PM
tranzam98's Avatar
what about the digital ones. i seen one on ebay that reads the voatage off the sensor. is it any better.
http://cgi.ebay.com/ebaymotors/ws/eB...&category=6773
Old Feb 22, 2003 | 04:48 PM
WS6 GreeN's Avatar
If you think you're running rich, easiest thing to do if you have ATAP is to monitor your O2's anyway, but knock most importantly. Do a few fourth gear runs with autotap, and review to see if there was less than 3 degrees of knock. If you see there was no knock, lean it out another 2%. When you start getting knock, you should stop adjusting. I did this with mine, and on the wideband, only had to change it 2 more percent lean. Hope this helps.
Old Feb 23, 2003 | 08:08 AM
Slowhawk's Avatar
LS1Tech Sponsor
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by tranzam98:
<strong> what about the digital ones. i seen one on ebay that reads the voatage off the sensor. is it any better.
http://cgi.ebay.com/ebaymotors/ws/eB...&category=6773 </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I run this in my car,just like A-tap.works good.
Old Feb 24, 2003 | 12:10 AM
strokedls1's Avatar
A digital read out will give the same numbers as atap, but it is difficult to watch the o2 voltage during wide open runs at 100+ mph. Easier just to log wide open runs with atap, and that way you can also monitor coolant temp, air intake temp, timing advance and knock retard. I usualy shoot for an o2 voltage of between .905 to .915 volts.
Old Feb 24, 2003 | 05:00 PM
tranzam98's Avatar
i just want to watch and make sure i dont to lean when i spray.
Old Feb 26, 2003 | 08:27 AM
Dave@Ramchargers's Avatar
You could always run a Scanmaster like i do.. its on my dash and in my view while im at WOT. you cant see real time 02 #'s and Knock retard.
https://www.ramchargers.com/cgi-bin/...890&cat2=26891
