A/F ratio and high altitude
Common sense tells me that because the air is less dense (less oxygen) that it would cause a car to run more rich.
Or does the pcm "re-learn" when going from low to high altitude keeping the A/F the same as before?
<strong> MAF measures the true amount of air intake so
first order, it doesn't matter. This is unlike
carbs. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">So when moving from IA (1200 ft) to CO (5000 ft) the MAF can tell there is less air and adjusts the amount of fuel accordingly therefore keeping the A/F the same?
