Thermostat Question
Old Feb 22, 2006 | 09:22 PM
Shooter9's Avatar
Default Thermostat Question
I puit the hypertech 160 in my car and it was already tunned for the fans to come on quicker. My question is I never saw a change in the temprature gauge. Is their anything else I need to do or is this normal?
Old Feb 23, 2006 | 12:04 AM
Shooter9's Avatar
TTT......any ideas?
Old Feb 23, 2006 | 12:18 AM
618HAWK's Avatar
What year is your car?
Later years were not correct. Basicly a dummy gauge. Do not recall effected years. I am sure someone will add to this. I think it was anything from 00-02???
I know 98s read correct.
Old Feb 23, 2006 | 12:20 AM
horist's Avatar
99+ F-Body's use dummy gauges.... 98s are the only year that use "real" temp gauges (98 cars had a direct temp feed to the gauge cluster... 99+ rely on the PCM .. )
Basically... most people are morons.... if it was 50* on 1 day and 0* the next.... and the temp gauge wasn't the same... they'd go in and complain the car wasn't running right... (most people don't understand how cars work... as such car companies need to dumb the gauges down)
to fix this.... GM made the gauges dummy gauges .... basically three levels.. warming up (left to middle) ... operating temp (anywhere around middle) ... too hot (right of middle)
You need a scanner to see what the cars actually operating at
Old Feb 23, 2006 | 12:29 AM
618HAWK's Avatar
That was quick, I new someone would jump in. Missed it by 1 year.
Old Feb 23, 2006 | 01:17 AM
Shooter9's Avatar
Thank yall very much.
Old Feb 23, 2006 | 02:08 AM
RedWS6 00's Avatar
I change mine to a hypertech 160 degree, The guage on the dash never gets to half way anymore, with my old thermostat it did. So look lke the guages on the 2000 cars work, and isn't a dummy one.
Old Feb 23, 2006 | 09:09 AM
The Alchemist's Avatar
UNDER PRESSURE MOD
I have a 2000, and the gauge reads the same mark if the car is running at 160 degrees or 210 degrees according to autotap readings.
Old Feb 23, 2006 | 10:26 AM
chrisj6's Avatar
they are still dummy guages, mine was reading right when i had a 195 stock thermo in, now with my 160 it sits on 185 when my actual temp is 176.
Chris
Old Feb 23, 2006 | 10:32 AM
horist's Avatar
^^^ yup, as mentioned, even though there is a slight change in the position of the needle, it's not reading accurate (on 98s , you can see fluctuations in temperature by looking at the needle, whereas 99+ don't fluctuate anywhere near as much)
98 cars had a feed that came right from the sensor to the gauge cluster (3 prong temp sensor) , 99+ go to the PCM only, and then are fed via the serial data stream to the gauge cluster... this data seems to be dummied down.
GM (actually alot of auto manufacturers) do this because when you put a real gauge in, people get paranoid... They see the gauge fluctuate between when they're curising down the highway and then they get stuck in traffic and it gets hot... most don't understand this is normal (no air moving over radiator) so they bring it back complaining it's "Over-Heating"
