What exactly is TM?
Old Mar 10, 2003 | 05:34 PM
akw408's Avatar
Default What exactly is TM?
What exactly does TM (torque management) do? When would I ever adjust that value? Can anyone point me to a good source of info?
Old Mar 10, 2003 | 10:15 PM
CMNTMXR57's Avatar
Default Re: What exactly is TM?
TM happens between shifts and gear selector changes.
It is the PCM's way of retarding timing in order to soften the blow on the tranmission when it re-engages therefore adding longevity and also smoothing out the shift.
If performance is more your goal though, it can be turned down with either an aftermarket programmer or with LS1Edit/Predator/HPPIII if you wish.
Old Mar 12, 2003 | 08:24 PM
akw408's Avatar
Sounds like it only matters for auto tranny cars? Would it do anything on sticks?
And what do you mean by turning it down? In LS1 Edit, don't you just up the value of the TM? Like stock it's 350, wouldn't you go up?
Old Mar 12, 2003 | 10:43 PM
CMNTMXR57's Avatar
Stick cars do not have TM.
There are two tables that you need to turn down. One is the retard amount and the other is time delay. Turn them down both to "0" and you're set.
I'm sure those with autos can tell you exactly what they did in greater detail, but that's it in a nutshell.
Old Mar 13, 2003 | 12:30 AM
DeathDealer's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by CMNTMXR57:
<strong> Stick cars do not have TM.
I'm sure those with autos can tell you exactly what they did in greater detail, but that's it in a nutshell. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">LS6's do <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Mar 13, 2003 | 05:42 AM
J&JsTA's Avatar
Look in the Transmission section near the bottom... there is a blow by blow of how to remove http://ls1edit.slowcar.net/faq.html
Old Mar 13, 2003 | 07:33 AM
IM LOWR's Avatar
I never felt TM until I got my 3000 converter, it feels like I'm stepping on my brake when the tranny shifts. I wonder how bad it is hurting my 1/4 mile e.t. and mph.
Old Mar 13, 2003 | 11:14 AM
Team ZR-1's Avatar
I'm sure those with autos can tell you exactly what they did in greater detail, but that's it in a nutshell. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Not so, MN6 based cars also have torque mangement, it is there to protect ANY drivetrain.
What is does not have is the Abuse mode that A4 trannie has. Look at the tables and you see torque values for all 6 gears (MN6)
Corvette also uses T.M for active handling/traction control but TM has more of an overall effect with an A4 as well as misfire does, they both control what mode the torque converter is in where on a MN6 just timing is yanked when TM kicks on.
<small>[ March 13, 2003, 11:21 AM: Message edited by: Team ZR-1 ]</small>
