Idle surge since tc installed
motor more at idle, and any overshoot in IAC
servo position will let the RPM jump more.
The IAC will be more sluggish and slower /
more prone to overshoot and retract, as it
ages.
Lean mixture at idle also tends to make the
motor more "twitchy". You might look at the
idle trims and see if they're indicating
lean. Not much you can do about it with the
Predator, you don't have that "****". But
if you detect an overall lean bias a MAFT
might be the way to go. The GMAF may be
contributing to a lean mixture; it's been
reported to before.
