How Do I Perform a Crankshaft Sensor Relearn Procedure?
Old Mar 29, 2003 | 08:22 PM
KYSpeedFreak's Avatar
Default How Do I Perform a Crankshaft Sensor Relearn Procedure?
Just as the topic says.. I need to know exactly how I do a Crankshaft Position Sensor Relearn Procedure....
Thanks
Old Mar 30, 2003 | 01:47 AM
2000SSNB's Avatar
Default Re: How Do I Perform a Crankshaft Sensor Relearn Procedure?
The only way I know is to go to a dealer and have it done with a Tech 2 device there. I am not sure if
any aftermarket programer devices have this function.
In my case I bought a second PCM, had it re-programmed after ta cam install. It was not
set-up for this and the code came on. My stock PCM was fine but not optimized for the cam etc. I send the unit back and the programmer took out the funciton.
Gert
Old Mar 30, 2003 | 02:34 AM
pekkaz's Avatar
EFI live claims to have this :
"Tooth error learn mode - Puts the PCM into a mode where it can learn the crank tooth error correction"
Is this the same thing ?
Old Mar 30, 2003 | 11:33 AM
Should any of the dealerships be able to do this and should they know exactly how to do a crankshaft position sensor relearn?
Some of the mechanics around here dont seem to know as much as they should...
Old Mar 30, 2003 | 01:35 PM
glitch77's Avatar
Ive got EFILive (with bi-directional controls) and it lets you do it at the click of your mouse. Shell out the 350 smacks and get it, you wont be sorry.
Old Mar 30, 2003 | 08:52 PM
01redws6ta's Avatar
This relearn procedure is very simple and takes about two minutes to do with a Tech 2. I am a technician at a GM dealership and have done many. Our dealership would probably charge 1 hour labor to do this. Any dealership technician should have the knowledge to do this it would seem. Good luck!
