Rev Limiter Setting
Old Mar 14, 2006 | 09:32 PM
solocus's Avatar
Default Rev Limiter Setting
What do you all recommend for a rev limiter setting on a all bolt on car? What was the factory setting?
Old Mar 14, 2006 | 11:19 PM
00ls1's Avatar
Possible Scammer - Buyer Beware - Issues Unresolved
you need to look at your dyno graph and see where your car makes peak power then set your rev limiter a little higher than that
Old Mar 14, 2006 | 11:40 PM
Lithium's Avatar
SSU's Drunk Typing Whore
I wouldnt go much higher then stock myself.
Old Mar 15, 2006 | 12:37 AM
Full-Force's Avatar
stock is 6200
Old Mar 15, 2006 | 05:07 AM
Justin00SS's Avatar
All bolt-ons and only 307rwhp?
I thought the m6s dynoed like 305 stock?
Old Mar 15, 2006 | 07:26 AM
solocus's Avatar
I need to update my sig
Old Mar 18, 2006 | 04:11 PM
WILWAXU's Avatar
Or at least that's where I ran mine
Old Mar 18, 2006 | 08:45 PM
mcflyz28's Avatar
Ditto 6600 here also.
Old Mar 18, 2006 | 08:58 PM
Blacker's Avatar
Leave it stock with the stock cam/valvesprings. You will experience valve float and peak HP is at 5200 rpm anyway.
Old Aug 25, 2006 | 08:13 PM
Frostbite's Avatar
At what Rpm do you experience valve float? I need to take my stock cam/spring car to 6300 to finish the quarter, will it float?
Old Aug 26, 2006 | 06:41 PM
RrCoX22's Avatar
ha! beat you guys... 6800 here
Old Aug 26, 2006 | 08:19 PM
ls1muscle's Avatar
no, don't worry about it.
