ANOTHER overheating issue with the WB????
Old May 11, 2006 | 04:00 AM
MeentSS02's Avatar
Kleeborp the Moderator™
Seems like it is a problem on the newer units...mine came from their second production run, and it has been flawless up to this date (and I run it full time in my exhaust). Keep in mind, though, that the LC-1 itself does not have a gauge. You can hook it up to a gauge as I have with the Innovate XD-16 (a very nice gauge), but that is extra money.
Old May 11, 2006 | 03:28 PM
TT_Vert's Avatar
my ls1 worked great for the first 2 hrs. now it jumps between 12 and 18 AFR. W/ the car off its at 20.9 as it should be. But when i go WOT its at 7 (pegged rich) and I know the AFR is fine. I verified its not my wiring as logworks says the same thing HPT says. POS!!
Old May 11, 2006 | 07:29 PM
joecar's Avatar
Flawless since I got it (June/July 2005), and I have been running it full time (except while I took it off car to chop the wiring up to crimp on proper oem connectors earlier this year).
Old May 11, 2006 | 07:57 PM
bmfcamaro's Avatar
how do you have it ran. is it in place of the narrowband also or on its own?
Old May 11, 2006 | 08:47 PM
WS6FirebirdTA00's Avatar
well im on my second and about to be 3rd controler, wired up the same way in the 2 other cars i put it in as well. i dont know what the problem is
Old May 11, 2006 | 08:48 PM
TT_Vert's Avatar
i just played w/ my LC1 again,a nd sure enough it works perfect for 3 or 4 mins. then it goes to hell. Starts reading 20 then 7. usually resting on 20 or so. WOT is 7 lol Yet it''ll work perfect for a few mins. My LM1 never had an issue w/ this.
Dave
Old May 11, 2006 | 09:58 PM
cantdrv65's Avatar
Post
Ive had my Lc1 running as the stock narrowband for about a month now, works perfectly so far, and I only did the intial open air cal. I also wired up the heater circuit using the stock NB O2 heater 12V power. I cant see it switching(as stock NB) beacuse I think I have the scan rate set too fast(lost my freaking serial plug) but it passes the emissions switching check, and the WB output works great.
Old May 12, 2006 | 08:46 AM
ESR's Avatar
ESR
LS1TECH Sponsor
heheheeh Never had a problem with my lm1 either.
Originally Posted by WS6FirebirdTA00
you calling me stupid? lol
yeah man i got it all wired right, the controller went out on me a week after i got it so i redid everything, called up innovate and spoke with some others. i had it wired correctly the first time as well. i also did 2 other cars the same exact way and they havent had any issues.
Old May 12, 2006 | 08:50 AM
horist's Avatar
mine's overheating on me too w/the LC-1 ... same sensor not a problem w/the LM-1
I'm installing the 90 dollar heat sink today ... I have mine in the collector
Old May 12, 2006 | 09:23 AM
MeentSS02's Avatar
Hmmmmmmmmm...this seems to be a recurring problem with the newer batches of LC-1s...mine has never done it, even in the collector.
Old May 12, 2006 | 11:03 AM
same deal for me man, i made a shield for it and it did nothing. PITA esp when you have some great data that gets messed up by a wb overheating
Old May 12, 2006 | 11:25 AM
  #32
MeentSS02's Avatar
Well, my wideband doesn't overheat, but my Serial EIO sure does
Old May 12, 2006 | 12:46 PM
  #33
Black02SS's Avatar
I am sorry, but maybe that is your burrito warmer Steve.
Old May 12, 2006 | 02:02 PM
  #34
Old May 12, 2006 | 03:05 PM
  #35
MeentSS02's Avatar
Oooooooooooooooooooooooooooooooooooooo...
Old May 12, 2006 | 11:56 PM
  #36
LoWeLL216's Avatar
Just to add another in the mix. I'm currently waiting on another unit as well. Same overheating problem. After rewiring it several times per innovates instructions I ultimately ended up buying a new O2 sensor after they advised me an overheating sensor (in free air) is probably damaged. Got the new sensor...same problem. God I hope the new unit doesn't do this...
Old May 13, 2006 | 12:01 AM
  #37
SmokingWS6's Avatar
The LC-1's are either defective or have different operating paramaters. I have the LM-1 and i've never seen it overheat, its been in efi and carbed cars. Sometimes in the collector.
If wonder if the problem is related to wiring? Bad ground, excessively long wire runs, narrow guage wiring, bad positive connections ect? I'm not sure what the units wattage rating is but i've felt the cigg lighter plug become warm after use.
Old May 13, 2006 | 12:40 AM
  #38
horist's Avatar
tried the ripoff heatsink... but where my O2 sensor is located... the heatsink + O2 sensor interferes w/the transmission bell housing
Gotta get a new bung installed further downstream
my LC1 uses alot of my LM1 parts... alot of splicing... but all good connections, wires as short as possible.... my weak link is I'm using hte cig lighter still for power/ground
I can drive for 20 mins no prob...then it overheats... other times it overheats quickly.... so far I've just been unplugging it and plugging it back in (cig lighter)
I replaced my spark plugs today and the old ones weren't too good of shape... so maybe that was part of it....
hopefuly if it ever stops raining, i'll be able to test it at the track in the morning (car's ready, all grease fittings regreased, rear is finally centered, fresh oil, fresh spark plugs, fresh trans fluid, fresh diff fluid, new plug wires, all coil pack connections cleaned, new fuel filter) slicks are on, tow arranged ... but track is 160 miles away so depends on this mornings weather )
Old May 13, 2006 | 09:05 AM
  #39
HavATampa's Avatar
This is not what I wanted to hear. My LC-1 worked fine for a full day and a half and started getting the dreaded 8 blinks of the led and the 20+ readout on the gauge. I bought another sensor from the VW dealer but haven't installed it yet. Looks like it might be just a waste of time now. My sensor was installed in the header collector in place of the pasenger O2.
Old May 13, 2006 | 09:37 AM
  #40
the snesor that throws the heater code for the lc-1 i use on my lm-1 all day long with no issue.
