hp tuners no open ports
has any one got this error message, and how did you solve it. I am using a working usb to serial adapter i/o gear. it worked flawlessly then on day, it was a no go.
I tried all of the usual cpu restart, check port fuse, lighter fuse/and like I said it worked before.
I posted this on hp tuners site, but no responce, figures
I would shutdown any unnecessary programs like AV during read/write regardless... also if you have any palm/pocket PC software installed I've seen those lock the serial port so other apps can't access it
Also make sure that the settings for the serial port (the usb to serial port) in control panel/device manager match those in the help file
hmm, checked all of that, still nothing, I am going to buy another serial to usb adapter tonight, I can not understand why this thing is not opening ports, anyone no if there is a cmd line to check my open ports, thinking the antiworm/trojan software could be stealthing them, thinking this is the problem.
Thanks
well, the best thing to see if your getting power is push in the lighter. other than that the fuse is 11 next to the driver door, label cig/assory hope that helps.
Now back to the issue here, I changed it to com4 com3 com2 and com1, nothing still, I disabled eveything in the start menu running in the back ground. Any other ideas?
Jumped the serial cable, and opened hyper terminal, got connectivity, so I thought there was something else here, so I shelled out another 45.00 and bought a new connector, it is a Belkin, so I was not expecting much from it, and it worked? Guess the I/O adapter just **** the bed? Who knows, I am looking in to their new usb cable, so hopefully this will not happen again.
