Logging MAF frequency
"1.) Make sure you log Dynamic Airflow vs MAF Frequency (Hz) In HP Tuners it is measured in lb/min so we will have to convert this later for the MAF table (g/sec)."
How do you setup the histograms to do that?
1. Select the # Histogram you want to use.
2. Click on the Configure Histogram button next to #8.
3. Type in the name of the histogram.
4. Click on the PID Heading and expand the Engine list. Expand the Airflow list and select Dynamic Airflow.
5. Select the units you wish to use. I use g/sec with the decimals set to 2.
6. Set the Plot coloring to what you wish. I use 512g/sec as the high and 0g/sec as the low.
7. Select the Table heading and select the MAF Airflow vs. Output Frequency.
8. Make sure the unit is Hz.
9. Click the save button at the top of the window.
On the table display, you can individualy set each parameter to SAE ot Metric. I use Metric for the airflow parameters.
