Equation for Air flow in gm/cyl?
Old 03-28-2006, 07:24 PM
heavyfoot's Avatar
Default Equation for Air flow in gm/cyl?
Does anyone have an equation to convert MAF airflow in gm/sec to gm/cyl. I'm using ls1 edit which has hi/lo octane table in rpm vs. gm/cyl. EFI live spark advance table is in rpm vs. gm/sec. I tried using the equation Airflow gm/cyl = MAF gm/sec * 15 / RPM, which I found in the EFI live help file. However when I log data the recorded vs. commanded spark adv does not match up. Any ideas?
Old 03-28-2006, 07:30 PM
SSpdDmon's Avatar
In EFI Live, the spark tables use grams/cyl and you log that with the GM.DYNCYLAIR_DMA pid. If you want grams/sec, you should just log the GM.DYNAIR pid.
Old 03-28-2006, 08:21 PM
heavyfoot's Avatar
Smile
thanks I'm a newbie!
Old 03-28-2006, 08:41 PM
heavyfoot's Avatar
I couldn't find the GM.DYNCYLAIR_DMA pid. I did find the pid GM.LS1.CYLAIR pid which appears to be in gm/cyl. I'll try it tomorrow.
Old 03-30-2006, 08:28 PM
heavyfoot's Avatar
I tried the GM.LS1.CYLAIR pid but EFI live told me it was not a supported parameter for my vehicle. car is 99 WS6. should work. i'm running efi live v5. any suggestions?
Old 03-30-2006, 11:24 PM
HumpinSS's Avatar
Yeah get the lastest version of the scanner and try again to see if it works. Send Blacky a pm about the upgrade www.efilive.com/forum
