which programmer is best
superchips
crane
jet
hypertech
diablo sport
if there are any that im forgetting worth mentioning let me know
. This will give you the most bang for the buck after investing all that cash in your mods. If you can, buy the software instead. It will be a long term investment that will pay for itself in the end. That is going to be my next purchase (LS1 edit or EFILive) after the subbracing and the 160 thermostat go in.
I'd say if you are gonan shell out 3-500 for a compelte dyno tune, you may as well look into getting a few other mods as well, like gears/cam and tb/intake etc. just my 2 cents,
im almost done doing full boltons, im ordering my headers and ory nextweek. the onlything i havnt done (bolton wise) is the maf (mine is stock but descreened).....im eventually gonna do cam but im holdin off for a few more weeks.....but gears are deff on my list.. mabe ill do that before a programmer, im still sportin the 273's :-(
thanks
Hope you didnt get screwed. I'm going from my heavy cammed motor to a Procharger later this year. Even though the Crane has supercharger settings, I'm 100% getting a dyno tune this time around.
I paid about 429. If I was selling it I'd probably take 320. It's transferrable to other cars.
- tune for any cam/head
- tune for any bolt-on/power-adder
- tune for OL and toss the NBO2 sensors if you want to
- tune for SD and toss the MAF sensor if you want to
- tune the MAF
- tune spark tables
- tune PE tables
- tune for economy/power/emissions as you want
- tune idle speed after cam/head install
- correct the speedo for different gear/tire
- change fan on/off temps to suit TS/weather
- change part throttle and WOT shift points
- change shift firmness
- reduce/remove TM/TR
- delete any power-robbing smog device
- run a custom operating system
- swap to a 4L80E and modify the calibration to suit
- fine tune some small thing that would otherwise not be worth running back to the tuning shop for
- just about anything else short of washing laundry or making coffee
- save alot of money by doing it yourself
- learn alot by doing it yourself
Drawbacks:
- learning curve, but it's not too bad
- costs about half as much more than a handheld
- you'll need a PC/laptop to edit the tables
- you'll always be "fine tuning" some parameter or other
- your Mrs will miss you
- you may not like/enjoy the technical aspect
If you try it you'll be hooked, but it's not for everyone.
- tune the MAF
- tune spark tables
- tune PE tables
Drawbacks:
It's not for everyone, but if you decide that you want to persue it, you definitely will not be disappointed.
