SD tune with FI worth $1000 more
I know some of the other benefits of a SD tune is the ability to run whatever desired boost level you want vs. having to have a daily driven tune for lower boost and a race tune for high boost with race gas. Also, the ability to set boost against RPM or gear. That was my main reason for doing it. My same setup on a friends car was useless until third gear and rolls under 70. I would like to run say 9lbs in 1st gear, 12lbs in second and max boost (15-16) the rest of the way. Will it be possible for me to run 9lbs in all of first gear, 11lbs at the beginning of second gear and ramp it up to max boost by the end of second gear, or is that asking for toooo much?
Another one of my main concerns is running methanol. I like the idea of being able to run less boost and make the same power but what do you do when temps are colder down in the 30's and it isn't (as) neccessary anymore, or does it still help? Isn't the tune based around running methanol? Will the engine compensate if I turned it off? How does this work?
I can tune my car for free or spend $470 on an Eboost2, $80 on a MAP seonsor, and $200 for the additional SD cable. Thats $750 plus time if I'm charged which could easily go above $1000. Is it worth it? I was also told it was more safe than MAF. In what ways?
The Intake air temp sensor would be used to determine temp changes in outside air...
Some people also run closed-loop in SD mode.
Exactly,
Just because you have no maf sensor on the engine, doesnt not mean the computer dont have the ablity to correct fuel conditions.
The Computer does not fix the Maf signal with fuel correction.
It corrects the incorrect Ve table via trims. So, That being said, Why would it matter if the maf was there or not if it is just another sensor that the computer cant correct the signal of..
On the Efilive custom operating systems, you can adjust the main fueling tables via intake air or coolant temp if you want.. But those changes would normally only be needed if you are in open loop with no fuel correction. If the o2s are on and in good operating condition, Semi closed loop state does very well.
