E10 In NJ?
Old May 20, 2006 | 04:13 PM
Tony Touch's Avatar
Default E10 In NJ?
I am looking for gas stations that are using 10% ethanol in central Nj. The only ones that are displaying it on their pumps is hess. The sticker says" All motor fuel contains 10% ethanol.
I figure I would rather run e10 than support those arabs. Cut them off a little at a time 10% in the long run will make a difference
Old May 20, 2006 | 11:07 PM
Tony Touch's Avatar
does anyone know of any stations in central nj that are displaying 10% ethanol
Old May 20, 2006 | 11:21 PM
qwikz28's Avatar
almost all man.
Old May 21, 2006 | 10:08 AM
Tony Touch's Avatar
thats funny because i have been checking around and hess are the only ones displaying it on their pumps
Old May 21, 2006 | 01:51 PM
qwikz28's Avatar
where are you from?
(come check out njfboa.org btw)
Old May 21, 2006 | 07:10 PM
Tony Touch's Avatar
Central NJ
Old May 21, 2006 | 07:52 PM
qwikz28's Avatar
where im in Piscataway and all i see is 10% ethanol at every damn station
Old May 21, 2006 | 09:09 PM
Tony Touch's Avatar
south brunswick i guess it has not made it over here yet. Funny because your only 25 mins away
Old May 21, 2006 | 09:16 PM
BlackHawk T/A's Avatar
Your car actually runs right on that stuff?
Old May 21, 2006 | 09:21 PM
Syxx613's Avatar
theres no reason why it shouldnt run fine. it is just a little more corrosive over time on the fuel system. the PCM can adjust to quite a bit of different changes.
Old May 21, 2006 | 09:47 PM
Jeff 97 Formula's Avatar
Here in Central NJ, I saw the "10% ethanol" sticker at BP, Amoco, Sunoco, Hess, Garden State, Wawa, One Stop. I did not see at any Exxon in NJ, but did see in one Exxon station in NY.
Still stumped on using E10 and HPP+, I removed the power tune from the custom tuning program since I can't get a straight answer on the HPP+ and E10 combo (only chose 160* stat and shift firmness). I find it hard to believe that nobody's out there who used HPP+ power tuning and E10. Anyway, the car seems to run the same with the old MTBE and the new E10, but starts a bit harder. Still performs at WOT with no hiccups, idles just as smooth.
BP/Amoco Ultimate 93 is what I use all the time.
Old May 22, 2006 | 07:09 PM
Tony Touch's Avatar
well bro finally at bp i saw the sticker 10% i am going to fill up tomm. I have a predator tune so i will let you know how it runs
Old May 23, 2006 | 07:34 PM
Tony Touch's Avatar
so far cars has run just as good if not a little more *****.
