COT Enable?
I had the car dyno-tuned last month, and noticed that the tuner left COT enabled.
So, what does that all do?
What will change if I disable it?
Either it's a feature there for cars that don't have COT, or it's used in other calculations we don't know about that aren't affected by COT.
Anyone know?
Anyone know?
But since my car was already dyno-tuned, if I go and disable it now, without any other changes, is that alright?
I dont know what I would need to change in any of the VE tables.
You can normally do a quick dyno run in a low gear on a lsx car without having COT kick in, but anytime I have done a 3-4 gear pull, it kicks in at the top of the run, killing power.
Ryan
already wandered off the reservation then there
is no reason to blow excess fuel out the exhaust.
You could have the COT max enrichment set to
your lowest PE table value and have some, non-
interfering quench but whether that would actually
protect anything, dunno. Better than nothing but
maybe not by much.
It's not true to say that having COT enabled,
makes the PE table nonfunctional. That only comes
about after you've been on it enough to wake up
the COT protection action. But once it's awake,
it'll ride your *** for a long time.
These cars (F-bodies) are set up like sprinters and
this is one thing that fights sustained high power
output.
Car would perform ok untill you got up it for a period of time and COT kicked in.
maybe not by much.
output.
When I was runing for WOT on the street originally, we set the PE to command 13.0:1 and immediately did a WOT pull (first WOT pull). COT kicked in right away and showed us 11.8:1. We scaled the MAF back and still saw 11.8:1 on the next run. We knew something was up, disabled COT and immediately saw 12.9:1 on average at WOT.
I should check the enable ranges and see whats up. I know it's stock, but it seems to kick in right away on my ride. The temps were cool that day too. Perhaps it was because we'd just come off the highway... not sure.
At any rate, going to have to play with this. I might just enable it again in a new tune matching the one I've got now. When I head to the track, load up the other tune or just disable it.
Any knowledge on how others get around this?
Thanks for the response!
Would the rear 02's be responsible for activation of COT???
If so, the fact that I don't have them on might be why it's ALWAYS on... sort of a Just to be safe kind of thing the PCM is doing to me.
A buddy of mine has his rear 02's in and enabled. He didn't have the issue with COT always coming on.... I think I know why now..
Anyone verify this???
just log your "commanded air fuel ratio" with your scanning software to see when it kicks in. Mine kicks in around 5000 rpms on a loaded mustang dyno run in 4th gear.
Ryan
Ryan
