does my car need a new tune
With the cam it has (G5x2) i have been told the dyno numbers should be a bit higher. It has stock heads. Other mods are ported t/b, ls6 intake, MAC headers, true dual exhaust with X pipe, no cats, 3.42 gears, stage two transmission, lid, and a "tune". yank 4400 converter
Tune was done by a local shop in the orland park area.
Im going to have to get the car retuned because the car doesnt like to idle good all the time. Idles very bad in reverse, and quits with the a/c on.
Im thinking about taking it to ls1 speed and see what they can do with it.
Before i do anything though i would just like a few other oppinions.
idling has got to do with the IAC and the desired airflow versus what its getting, thats all your idle is. the guy that got it 'tuned' might have only gotten WOT and part throttle tuned and as most people do.....not worry about the idle and think that the car is supposed to surge and cut off like they do...wrong. get your actual airflow up with your desired airflow and i will gaurantee it will idle better. and don't forget to add more air for when the fans come on. hell if you need help try WS6FirebirdTA00 up here, he has done idle for his car and it runs perfect. he has f13 cam and AFR 205 heads
How does...intake manifold, ported t/b, crank pulley, lid, headers, true dual exhaust, AND a cam only give me a 75 hp???
I was talking to other guys with pretty much the same mods as me but a much smaller cam (224/224) dynoing ~430
IF you get a/F correct for the track/street
it will be extremely rich on the dyno and will show low #'s
I wouldnt worry too much...
local guy I tuned was running 11.3x and was only 379 at the wheels...
tuned for A/F on the track
Either way I’m more concerned about the whp
The idle tuning has nothing to do with the WOT tuning. You probably need to get your idle tuned. And this will have NO effect on you whp or 1/4 mile time.
Eric you are very good at tuning, why don't you get HP Tuners? IMO You could tune everything to your liking.
As far as my track times and rwhp. The air was perfect that day and I was running the skinnys and had pass. seat out. The day I was running high 11s was stock wheels up front full weight in junk air (baro was 29.7).
