lc-1 reads 20.0 after warmup wtf??
Originally Posted by Jpr5690
Also Im Guessing That During A Free Air Cal The Sensor Needs To Be In Clean Air
Finally My Procedure For The Calibrations Is Gonna Be First Peform The Heater Cal Then Peform The Free Air Cal
FOR WHEN I WIRE UP THE NEXT UNIT DO YOU ll reccomend putting the heater ground with the signal grounds or having the grounds seperately
i orignally had them seperately yesterday but during my talk with innovate they had me move everything to a common ground.. i dont know if this was just for testing or how it should be
Just To Verify The Black Calc Wire Gets Hooked To A Pushbutton Switch And Then To A Ground So When You Push The Switch It Grounds That Wire And Starts A Free Air Cal?
Edit: Innovate have recently had a bad batch of LC-1 modules.
