drop in rpm between shifts, what
what table tightens up the 1-2 and 2-3 shifht at wide open throttle.. i have
2.73 and it dropps 2000 rpm between shifts.. thanks
Using a healthy nitrous shot also tends to increase shift recovery between 500 to 1000 RPM due to the increase in torque.
anyone else.. my tac drops 2000 rpm at the shift from 1-2 , 2-3 . this
seem to be a lot of slack... what tightens this up. time or pressure..
remember its stock but the lid and filter..
They're called gears. Unless you want to spend a $h!tload on a custom tranny/drivetrain, you'll have to live with it. Switching from 2.73's to 3.73's will help you get through those 2ooo rpms faster. So will more hp. What you're describing is not in the tune...it's mechanical.
