ses light flashing
Old Jun 5, 2006 | 08:43 PM
lmt0705's Avatar
Default ses light flashing
can someone tell me what this means? Thanks!
Old Jun 5, 2006 | 11:11 PM
2K2WS6TA's Avatar
Flashing SES is missfires, either random, or in a specific cyl
If the code is p0300 it's random, if it's p030x (x= cyl #) then it's in that cyl
Old Jun 5, 2006 | 11:23 PM
GET_SOM's Avatar
have you done ne mods recently?
Old Jun 6, 2006 | 01:56 PM
lmt0705's Avatar
installed d1sc about 3 weeks ago, ran car low on fuel when the problem happened. sti;; having intermittant problem.
Old Jun 6, 2006 | 09:20 PM
02wS6firechicken's Avatar
When your SES light flashes it means the car is misfiring and catalyst damaging. So basically its saying that something (most likely unburnt fuel) is causing the wrong emissions to run through your exhaust resulting in catalytic convertor damage. If you drive very long with it flashing like that you can melt down your cats(if you have them.
Old Jun 6, 2006 | 09:35 PM
ZL1Killa's Avatar
when you say ran the car low on fuel...did it cut off on you going into the gas station?
if so you might have pissed off your fuel pump... the fuel cools the pump, and it has been known that if you run them dry for very long at all that you fry em'
Old Jun 6, 2006 | 11:22 PM
Domestic Demon's Avatar
And if the fuel pump can't supply the engine with enough fuel to feed all the cylinders, that could cause a lean mixture and a misfire condition.
Old Jun 7, 2006 | 12:20 AM
Frost's Avatar
lean + FI =
Old Jun 7, 2006 | 02:09 PM
lmt0705's Avatar
I also forgot to mention, when I put my fuel pump in somehow I managed to leave out one of the little rubber feet that go on the bottom of the sump. (I found it laying on the ground after I finished installing it) I was wondering I maybe the pump sock is being pinched on occasion? it threw codes a few days ago 0152, 0300, 0302. O2 on pass side front, random misfire, misfire on number 6. The guy that tuned my car for me said hes seen this twice before and it was a bad O2 sensor, it just seems odd that this all started happening around me running extremely low on fuel
Old Jun 11, 2006 | 08:59 AM
Frost's Avatar
You should do a compression/leakdown test. Seeing SESs after running a boosted car lean is enought to make you sick to your stomach.
