Past basics, commanded shift-points ignored
Old Jun 12, 2006 | 02:56 PM
Frost's Avatar
Default Past basics, commanded shift-points ignored
Posted this on another board as well...
A member of our local F-body club just got a pretty radical project car that was a tune and a stall away from being complete. I haven't been tuning all that long, and this is my first real struggle with a persistent problem.
Here is a mod-list of the car copied and pasted from RPM's board:
All Spohn underneath; LCAs, Panhard Bar, SFCs, torque arm
Moser 12 bolt 3.73s
Weld in bar with the door bars removed
Stage 4 built 4l60E with hardened in and out shafts
3200 Precision stall
Walbro pump, relay, and hotwire kit
42lb injectors
Wideband and other guages
Rapid Motorsports built forged 402" LS2 based stroker
Air Flow Research 225 Heads
Comp Cams 236/238 .605" lift 114LSA
Fast 90 intake & Nick Williams 90mm TB, LS6 MAF
All hooker exhaust from header to catback
Full interior, AC, power options.
and more....
Engine has about 600 miles, trans has about 150, the car has about 55K.
Now, the ONLY issue I have left at the moment is shift RPMs @ WOT. Regardless of what I do, the car shifts in the middle 5800s from 1-2 and the middle 6100s from 2-3. Since it is a totally built up tranny, I dumped the tune that was there (that did the same thing) and went back to a stock 99 A4 tune. I zero'd the WOT shift MPHs and have tried an RPM range from 6000-6500 for 1-2 but I still get 5800s at shift. I have worked the MPHs in the part throttle tables at and near 100% TPS as well in vain. The only other item tinkered with is the shift times are all at a 1/4second. I have been from 0 to OEM on these as well. It did the same thing before the stall was installed on Saturday.
Here is the tune: http://frozenwaste.com/Frost/Tune/FBCBRET_Frost_15.hpt
Any ideas at all would be appreciated. Also if there are any other musts for a tranny like this, please let me know.
Thanks alot.
-Steve Williams
Old Jun 12, 2006 | 03:02 PM
Steel Chicken's Avatar
what tuning software are you using? if its HPTuners load your bin and ill look at it.
Old Jun 12, 2006 | 03:58 PM
Frost's Avatar
Yeah it's HPT, but I can't up the binary till I get home
Old Jun 12, 2006 | 05:08 PM
foff667's Avatar
LS1TECH Sponsor
I had the same problem with a built tranny on a stockish car...never got the issues ironed out...would love to hear if you ever get it fixed.
Old Jun 12, 2006 | 09:39 PM
Frost's Avatar
Here is the tune:
Old Jun 12, 2006 | 09:40 PM
jimmyblue's Avatar
Moderator
I'm wondering whether behind all the electronic
whiz-bang there is an old fashioned harware shift
governor, or something in the mechanicals that
tells the PCM it had better upshift and overrides
our settings.
If you bump the WOT MPH up higher does it refuse to
follow?
Old Jun 12, 2006 | 09:42 PM
Frost's Avatar
follow?
Yeah it sure does, but I haven't gone far if any over where it should land RPM-wise for fear of not shifting....
-edit-
Oh yeah, if you see anything overly odd in the tune, try not to hang me out to badly
Old Jun 12, 2006 | 09:56 PM
fast98's Avatar
how about a log. are you sure the tps is going over the 94 percent in order to command the wot tables?
Old Jun 12, 2006 | 10:06 PM
fast98's Avatar
does the car have stock tire size? i see you are using a 26.1 inch tire for your calcs. from the factory they use a 24.93 for the tire size. it prob wont cause your problem but just something i noticed
Old Jun 12, 2006 | 10:26 PM
Frost's Avatar
Lemme get a log.... the car has MT DRs, tire size is correct... every WOT log is constant wheelspin. It's kinda silly.
while i dig through my tuning laptop I can say now that I'm sure that TPS showed 100%.
Old Jun 12, 2006 | 10:40 PM
Frost's Avatar
I don't have the logs here, they are at work. Ironically...
Old Jun 13, 2006 | 11:09 AM
thats the first thing I was gonna ask, on the 05 and 06's GTO's theres some kinda weird issue where sometmies the TPS only reads like 88% even though its @ WOT. Id try lowering the 94% in this bin to 85% and see what happens. Nothing else looks odd to me.
Old Jun 13, 2006 | 11:20 AM
Frost's Avatar
I can lower it back down, but I am dead sure that the logs show 100%TPS during the WOT segments.
Old Jun 13, 2006 | 02:33 PM
SMOKINV8's Avatar
That's an oddity within the scanner, details here.
Who built the tranny, and can you find details about any valvebody changes that were done, or changes regarding its electronics? The tranny shop might be able to tell you whats up with the shiftpoints too.
Old Jun 13, 2006 | 02:54 PM
white2001s10's Avatar
I had a sort-of similar problem while trying to raise the rev-limiter on a 98.
No matter what was tried the limiter still kicked in at the same RPM range.
I found no resolution.
