? Inside....P0106 MAP/BARO CKT???
"P0106 MAP/BARO CKT Range/Perf"
It is a cam-only car and it was running fine for 1-1 1/2 yr's w/o any SES lights at all and now this comes on/goes off quit often. I replaced the MAP sensor and I dont know If that was the problem or not b/c it still comes on. Anyone have insight for me on this? Thanks in advance
Thanks Alot...thats probally the problem. Will this code cause any timing pulled, fuel added/removed, any other tunning issues? I recently dropped the idle a little so I could hear a better lope from the cam and thats probally it.
I did not think about dropping the idle 50 rmp's when I made the post. Slipped my mind.....It ran fine for a couple months after that was done and then started throwing SES .....May be the idle to low, may not ....dont know yet
