different IFRs for greentop 42#'s ?
They have varying IFR table values even though they all have the same injectors :
149338874.zip
43.65182 43.65182 43.65182 43.65182 43.65182 43.65182 43.65182 43.65182 43.65182 43.65182 43.65182 43.65182 43.65182 43.65182 43.65182 43.65182 43.65182
21553618252.zip
38.44336 38.62938 38.93941 39.06342 39.31144 39.68347 39.86949 40.17952 40.24152 40.55155 40.79957 40.92358 41.17160 41.41962 41.66765 41.85366 42.03968
19595224909.zip
216197490.zip
45.13995 45.57399 45.94602 46.00803 46.38006 46.75209 46.81410 47.24814 47.37215 47.80618 47.93019 48.24022 48.48824 48.73627 49.04629 49.29431 49.54234
Why is this ?
What are the IFR values for 42# greentops supposed to be on an otherwise stock tune ? (Tried search, found nothing).
I'm trying to figure out why my fueling is still all jacked up now that I've switched to a new bottom and and an LS6 cam.
Thanks,
Rob (Bad30th)
Why is this ?
Oh yeah, and your fueling is all jacked up because the flow characteristics are different. Different cam, probably a different quench, different pistons, etc.
After reading more it appears some people also alter this table to correct for tuning A/F. Ewwww.
I never understood what values to plug into the spreadsheet, can someone pls explain ? I know fuel pressure = 58psi, but what do I put in for rated flow pressure and flow rate ?
Today I'm going to attempt to start from scratch from my stock tune, adding known good values to try to straighten things out.
Rob (Bad30th)
Values:
Injector rated fuel pressure: the manufacture post the exact pressure the injector was tested at. yours are probably 43.5
Your rail fuel pressure: Stock is normally 58psi, If you have a boost pump or aftermarket hi flow pump i've seen pressure hover around 60 to 62psi.
Injector rated flow rate: basically what it states. 42lbs in your case
For example, i did this for 42lbs injectors rated at 43.5psi, 58lbs rail pressure
48.49827788 48.80053386 49.10092925 49.39949798 49.69627298 49.9912862 50.28456864 50.57615042 50.86606077 51.15432813 51.4409801 51.72604355 52.00954459 52.29150865 52.57196044 52.85092404 53.12842289
As you can see, no where near what some of the others were set at, as they were wrong, since they were compensating for not properly calibrating the maf, ve, pe table ect.
Sorry for being a noob, trying to learn...
plugging in those values give me :
48.4983
48.8005
49.1009
49.3995
49.6963
49.9913
50.2846
50.5762
50.8661
51.1543
51.4410
51.7260
52.0095
52.2915
52.5720
52.8509
53.1284
Is that correct ?
Rob (Bad30th)
Rob (Bad30th)
scroll up two post. i edited my post
I will give those a try, mine are WAY different in my current tune, 42.22570 to 45.449. Maybe that's why it's trimming in so much fuel.
Thanks for the explanation.
Rob (Bad30th)
Values:
ive looked at different files and some have it same across and some is like this
I was thinking of reflashing mine and starting from scratch too. Good luck getting things inline.Nino
After thinking this over, I'm unsure how changing the values in the IFR table to the (correct) higher value than I had will help my lean fueling/excessive trimming.
If we're telling the PCM that the injectors flow more in a given state it seems like it will lean me out even more ?
At least the wideband agrees that it's lean and the trimming is keeping it at stoich.
I will know more this afternoon when I try flashing the car with my new-from-stock tune.
Rob (Bad30th)
Any ideas why the calculated IFR table wouldn't work on an otherwise stock tune ? (raised idle, lowered fan settings, used my old spark table, old RAF table, that's about it except for transmission settings). I put my old tune back in and it fired right up and scoots down the road - but with 25% LTRIMS and STRIMs that are positive ranging from 5-20 ! That's adding like 30-45% more fuel !
...and the wideband agrees that the net result is stoich, ~14.7:1I'm confident it's not anything mechanical, I have a brand new forged bottom end and new LS6 cam/lifters - and the swap didn't cure the fueling problem. Blower bypass is vented to atmosphere.
Rob (Bad30th)
You're going to want to get the raf on point again, once thats done, move to ve. Do a few passes, add some more timing, do a few more passes of the ve, add a bit more timing, touch the ve again, then go for the maf and PE. Wish I was around to help
Wanna wait till August?
Good luck Rob!
Thanks for the ideas guys. I guess I will try to start from the top with the new IFR table and do RAF, VE and MAF and see what happens ?
Rob (Bad30th)
Good luck Rob!
idle speed, idle timing, RAF in gear and park, SD mode with my wideband to set VE by AFR error %, turn MAF back on and use AFR error % to adjust MAF table, measure actual vs. desired airflow to ensure they're close, set PE fueling and watch for knock, lather, rinse repeat...
Edit : Ah, I just had a light bulb moment.
The RAF that I plugged in is from my old 222/224:114 cam. I now have an LS6 cam, and -4cc valve reliefs on the new pistons. I will redo the RAF table and see what that does for me. Thanks for bearing with me guys, learning hurts sometimes, LOL.
Rob (Bad30th)
