motron 60# injectors....
and i set the IFR table to:
rated : 43.5
actual rail pressure: 58
injector size : 60
and i get like 8.8 i think it is or 8.08....can't remember right now
I am referring to the voltage offset table. This is the table that adds pulsewidth based on the battery voltage.
To be more specific, how do you verify what is a voltage offset error vs an IFR error?
do elaborate as I'm still new to this tuning....learning new things everyday
If I understand you correctly, the way to get the correct voltage table values for a given injector would be to take a stock car with a "close" tune (0 to -2 LTRIMS), swap the injectors, set the IFR table and drive/log system voltage vs. fuel trims for given cells ?
...by chance anyone got that table for greentop 42#'s or Mototron 60's ?
Rob (Bad30th)
rated : 43.5
injector size : 60
Z06 offset tables are closer to delphi injectors, i.e. less offset (faster) for the most part.
Rob (Bad30th)
In short, the injector offset is the amount of time it takes the injector to react. There are several variables that affect this, including type of injector, voltage applied and differential pressure, among others.
