LC-1 users come in
Old Jul 16, 2006 | 11:02 AM
jmm98LS1's Avatar
Default LC-1 users come in
Got my lc1 all wired up as a wideband and narrowband and seems like it's working....I'm getting readings on my digital dynotune gauge. Couple things though:
1. Logworks won't connect to the lc1, all the gauges stay grayed out even while I'm getting readings on my dynotune gauge. I've read on Innovate's forum that I need to update to logworks 2.0 to fix this, but when I go to their page to download it, they say "the page you requested is not available" and it gives me their site map listing. Am I missing something here?? How the hell am I supposed to update? Does anyone maybe have the 2.0 installer they could email me?
2. What kind of AFR readings do you guys see at idle? I'm consistently seeing 15.7-16.1 idling. Sound lean at all? It shoots down to 13-14 when I rev it a little.
Thanks guys!
Old Jul 16, 2006 | 11:43 AM
HavATampa's Avatar
Yeah, there website seems to be screwed up. I have v2.02 that I downloaded the other day. It's 5.5 megs in size. Might be to big to email but I'll give it a shot if you want me to send it to you.
Old Jul 16, 2006 | 04:37 PM
jmm98LS1's Avatar
Ok, got logworks working finally (thanks HavATampa!!), started the car and my dynotune gauge and logworks were working perfectly...fluctuating between 14.5 and 15 during closed loop idle. So I shut the car off and then turned the wideband back on and flashed the voltages I wanted in there to log wideband w/EGR through HPTuners (10:1 afr = 0v and 18:1 afr = 5v). Then I set up my PID's in HPT, started the car and started scanning. Now everything is puking all over the place. The dynotune gauge is reading 50:1 afr and logworks jumps all over the place, then logworks goes to 20.9 and stops working, my LED starts blinking and the gauge stops working. I tried setting the analog 2 output back to default, reset the whole lc1 calibration....still the same crap, didn't fix anything. Gauge shows 50:1 in open air now, where it used to show 20.9. Anybody have any clue wtf happened?? It was working perfectly until I changed the analog 2 output and now I can't get it to work at all. Help!!! This stupid LC1 has fought me since I opened the goddamn box.
My grounds:
heater is going to chassis ground, calibration wire is going to diff chassis ground and the rest are grounded through the EGR harness to the pcm (I think). Should be fine since it was working perfectly until I changed the output.
Old Jul 16, 2006 | 05:45 PM
ringram's Avatar
Use the software to reset the LC1 to factory defaults. Make sure you do a clean air calibration and power cycle the lc1 after calibration.
Old Jul 16, 2006 | 05:52 PM
jmm98LS1's Avatar
Update, I just tried the following:
Took sensor out of exhaust and flatlined the analog 2 voltage at 2.5. Measured voltage with multimeter at egr input (where analog 2 is connected) and got 2.5 volts. Checked it in hpt, 2.5 volts. The dynotune gauge changed to 25:1 instead of 50:1 like it has been . Flatlined to 5 volts, egr input measured 5 volts with multimeter as well as hpt scanner. Dynotune gauge went right back to 50:1. I checked logworks just for giggles and it said 20.9.
I recalibrated everything in open air and then put the sensor back in the collector. I set the analog 2 back to default settings. Now logworks is showing the correct 14.7afr at idle, hpt is showing .61v and ~10:1 afr (I used the EGR writeup sticky for my pids, so they should be right) and a multimeter showed .60v at the EGR input. Now the dynotune gauge is at 6.0!!!! WTF is going on??? It seems the lc1 is working correctly now through logworks at least, but my analog 2 output seems fubar'd. It flatlines voltages fine but it's not putting out the right voltage to the gauge and hpt once the car is running. Seems to me I should be seeing around 3 volts on the analog 2 output instead of .60---I'm so lost here. Any ideas?...will try just about anything.
Old Jul 17, 2006 | 07:02 AM
horist's Avatar
sounds like you fried your DAC (Digital to Analog Converter in side the cable)
If logworks reports the correct voltage, and you're sure the analog outs are configured correctly (which if you restored to factory defaults... the voltage should fluctuate a little), and the analog output voltage isn't changing then your DAC is dead ... time to contact innovate to see if they'll warranty it for you ... then in the future use a resistor between the output wire and the source (I forget the ohm rating... you're probably setting, search innovates web site... this is all over their forums)
Old Jul 17, 2006 | 10:57 AM
jmm98LS1's Avatar
Here's the thing, I can program the analog output to flatline a voltage (tried both 2.5v and 5v) and that's what the analog out is getting, 2.5v and 5v respectively. I read innovates forum and it seems folks that fry the DAC are getting a constant voltage on the analog outs no matter what they command. Looks like it's time to call tech support.
Old Jul 17, 2006 | 07:37 PM
98Z28CobraKiller's Avatar
Restricted User
When you find out what it is please post up. I am having the same problem with mine. I didn't get a data cable with the LM-1 that I am using but I am getting it tomorrow. My buddy just forgot to give it to me. I figured that I was seeing what I was seeing becuase I needed to define the voltage range. I am curious as to what they say to you. I am doing the same thing w/ HPT logging the AFR thruogh the EGR. Subscribed!
Old Jul 18, 2006 | 03:21 PM
Restricted User
ttt....
Old Jul 18, 2006 | 07:48 PM
jmm98LS1's Avatar
UPDATE:
Just got off the phone with Innovate tech support, didn't take 5 minutes. He didn't do any troubleshooting at all, I just told him what was happening and that I thought the DAC might be dead. He had me email my contact info so they can start an RMA for a replacement. Good customer service!
Apparently this problem is not uncommon, and there's a newer version of the lc1 with build in resistors to save the DAC from a fatal surge. Hopefully I'll have better luck with the next one.
Old Jul 19, 2006 | 09:11 AM
Restricted User
I just got my serial cable to define the anolog out voltages. I hope that this resolves my problem and I don't have to send it back for more delays in getting my tuning done.
Old Jul 19, 2006 | 09:52 AM
jmm98LS1's Avatar
Mine would allow me to flatline a constant voltage, but when I defined a 0-5v voltage range for say 10-18 afr, it would spit out a constant .60v and stay there. Good luck! Make sure your heater ground goes to the same place as your analog/system ground (back of head for ex.), just on a different lug. This is the recommendation made to me by innovate.
Old Jul 19, 2006 | 12:14 PM
Restricted User
I got it all working good. My LM1 was set with a range of .1v to 1.5v for some reason. I changed it and VIOLA! Wow, what a difference logging with the WB.
Old Jul 22, 2006 | 06:01 PM
HavATampa's Avatar
So what's the latest on this jmm98LS1? Did the new replacement LC1 get you going?
Old Jul 25, 2006 | 11:12 AM
jmm98LS1's Avatar
Just got the old one shipped off yesterday. Innovate says turnaround time is 3-5 business days plus transit time, so it'll probably be a couple weeks before I have another lc1.
Old Jul 25, 2006 | 12:15 PM
oupike1757's Avatar
I had mine in 6 buisness days back in my hands. THAT is how you treat customers.
Old Aug 11, 2006 | 01:11 PM
jmm98LS1's Avatar
Received my lc1 back in the mail today, it took a little over two weeks. I was under the impression it was being replaced with a new one, not repairing the one I had. Oh well, I'll hook it up this weekend and see if I'll be pissed or not.
Old Aug 11, 2006 | 04:48 PM
White.Lightning's Avatar
Let us know how you make out. I may have done the same thing. Mine will be fine at cruise, then jump to 50.x-60.x AFR....obviosuly wrong.
Good luck
Andy
Old Aug 11, 2006 | 09:19 PM
Doc's Avatar
Doc
Did I read your post correctly that Innovate told you to have the heater ground in the same place as the analog/system grounds?
Old Aug 11, 2006 | 10:33 PM
ninobrn99's Avatar
thats not right. the system and analog ground should be grounded to the same source. the heater ground to a different ground close to the others.
