When LTFT are positive, do I add to VE ??
Thanks
BTW, when you are logging, make sure you filter out decel and DFCO in your LTFT histogram, or it will throw your VE values off. Oh and un-plug the MAF.
How do I filter the decel and DFCO for the log??? That would make a difference because I am driving through some small hills and coasting sometimes.
To ignore coasting/idle or WOT fuel trim cells, setup a filter that excludes these values. Your expression should look something like this:
PID.6310>0 AND PID.6310<17
I believe FTC 0 is coasting and greater than 18 are idle and WOT.
It's also a good idea to set the 'cell hits required' field to 20 or 25 to exclude errant values.
FYI- PID.6310 is the PID for the Fuel Trim Cell (FTC). There's a posting of what all the FTCs are, but in general 1-16 is normal driving, 0 is coast or decel and 17-21 is Open loop, WOT, and some other stuff.
I just did this and no numbers post at all. What does that mean?
