Need help with Fuel Enrichment(HP Tuners)! Can't get over 10.5 AFR!
Yeah but my multiplied value from 4600 to 6400 is .98 which should be waaay to lean. Since it was reverting back to 1.25 with COT on it was not adjusting and I kept dropping it down little by little to see if I could get it to move on the dyno.
Originally Posted by ehirst83
I see. Well I edited my multiplied value to 1.15 and under 4600 rpm I was showing around 12.2 A/F does that sound about right? Should I change all of the values to 1.15?
Hmmm. 1.25 was where I started out on the dyno and my A/F was anywhere from 10.3 to 10.5. Once I moved it down to 1.15 my A/F was 12.2 on the money up untill 4600 rpm where it plummeted off the chart under 10.
Yeah my PE vs. RPM
Yeah my PE vs. RPM
Yeah my PE vs. RPM
Yeah my PE vs. RPM
Z'mnypit: that's a good point I'm sure the climate from here in Utah to Alabama is significantely different.
white2001s10: that's exactly what I'll do
Thanks again to everyone for all the input. I never would've figured it out alone!
You're not losing much power when the COT starts because you're already in the 11's AFR before that.
I'd try to bring it all back to between 12.8 and 13.2 AFR,
then adjust the spark for max power at that point.
That intake should peak around 6100. Your VE Table values are too high in the WOT portion. Are you in Open loop SD? If the PE table is commanding leaner than the OLFA table than the PCM will use the richer value.
#32
Well I disabled COT and reset my values to 1.13 where they were on the dyno with 12.5 A/F. It felt a little better but I could still smell it running rich. I double checked under the hood and noticed my damn IAT sensor had one of the wire pulled out! Kind of important when running in SD right. The only thing I have are IAT and MAP sensor. Could this be the reason for the low dyno?
