P1133 code
Old Aug 3, 2006 | 08:47 PM
01_ram-air's Avatar
Default P1133 code
Any suggestions why I might be throwing this code other than bad O2? Just replaced both a couple months ago.
Old Aug 3, 2006 | 10:02 PM
Grimes's Avatar
if that is an o2 insufficient switching code, then you can delete the code or try the rear o2 sensors from a 2002 vette (bosch 13111 i think?). Long tube headers will cause the code because the oxygen sensors do not heat up as much as with stock manifolds. The bosch ones mentioned have higher wattage heaters to help this problem. If I were you, I would just get the codes deleted, beacause sometimes the bosch's do not solve the problem
Old Aug 3, 2006 | 10:34 PM
01_ram-air's Avatar
I have no rear o2s since I don't have cats. those have been tuned out already. And I'm running bosch o2s up front.
Old Aug 3, 2006 | 11:35 PM
Domestic Demon's Avatar
I looked up that code and it appears that it pertains to the rear O2 Sensors...very odd, since you have simulators for the downstream sensors
Try getting the code reset. If it comes back again, then you may have to get the rear sensors disabled with a tune.
Old Aug 4, 2006 | 09:23 AM
01_ram-air's Avatar
I had the code cleared yesterday, I'll see if it comes back.
I don't have simulators, they are tuned out already.
Old Aug 5, 2006 | 12:43 PM
01_ram-air's Avatar
So, is the P1133 for the REAR O2s?
I thought that Bank 1 sensor 1 meant the driver side front O2???
Old Aug 5, 2006 | 03:56 PM
2001NBMZ28's Avatar
P1133 is bank 1, sensor 1 - drivers side precat.
Old Aug 5, 2006 | 04:30 PM
ZL1Killa's Avatar
DON'T buy the vette sensors!!! stupid waste of money
what did you change before you got these code(s)?
look up my previous posts and search for the p1133 code and p1153 code... sometimes they run hand in hand.
Old Aug 7, 2006 | 12:17 PM
01_ram-air's Avatar
I didn't change anything. Was just driving down the road and threw the code. Car seemed fine.
Old Aug 7, 2006 | 03:15 PM
ZL1Killa's Avatar
the p1133 is the front 02... not the rear
what have you changed on your car? have you changed injectors and what kind do you have?
Old Aug 7, 2006 | 04:14 PM
01_ram-air's Avatar
The only things that I've done to the car are the mods in the sig.
Well, Tr6 spark plugs, been running those for about 8 months, new ones about 3-4 months ago and MSD wires. Stock injectors.
Old Aug 17, 2006 | 01:26 PM
01_ram-air's Avatar
update/
installed new 02, problems resolved.
Old Dec 7, 2006 | 11:00 PM
minesfaster's Avatar
I have the same issue but i swapped out the 02 sensor with a used one and it didnt fix my problem. ALl i did was put the stock exhaust back on. couls this be why i am not passing smog ?
