Does lean cruise work in 2001+ PCM?
Old Aug 6, 2006 | 09:41 PM
Terry Burger's Avatar
Default Does lean cruise work in 2001+ PCM?
Using a popular tuning software I'm able to turn it on, and I put in the proper settings, but it doesn't seem to do anything (e.g., I don't see O2 values stabalize at some low value after x seconds of cruise @ 65mph). Has anyone else got it to work on your FBody? What kind of gas savings did you see?
Thanks,
T
Old Aug 6, 2006 | 09:58 PM
jimmyblue's Avatar
Moderator
It needs a little OS hack, GM killed it internally for US
legalities. People have gotten it to work. But support
for this is not much like "off road performance", this
is on-road emissions meddling so your tool vendor
may have certain reservations about supporting such
a hack (or rather, consequences of same).
Of course you could run full time open loop and get it
to do the same thing pretty much, so don't waste
your time trying to make sense of the situation. We're
talking bureacrats and legalities here, after all.
Old Aug 6, 2006 | 10:02 PM
Any directions for the OS hack? I understand why its blocked, but for some reason I'm able to enable it in the tuning software for 2001s.
Old Aug 6, 2006 | 10:21 PM
2xLS1's Avatar
It only looks like you are enabling it but in reality, you are not.
Old Aug 6, 2006 | 10:24 PM
wait4me's Avatar
The Efilive v3 or v5 custom Os can run any air fuel you want at any rpm or map.
Old Aug 6, 2006 | 10:41 PM
Ah, bummer. I know the GTO guys can enable it, and it works for them. I even went and typed in all the tables... =(
Old Aug 7, 2006 | 05:21 AM
RedWS6 00's Avatar
You can do something very simular to 'Lean Cruise' Mode
Run the car in open loop, it ignores the O2's. Then play with the EQ Ratio to choose what AFR you want based on MAP & RPM.
Old Aug 7, 2006 | 07:07 AM
Rob's Avatar
Rob
Only the '04 GTO's work
Old Aug 7, 2006 | 10:57 AM
Is it possible to tell the car to be in closed loop most of the time, but just to go in open loop when I'm going over 70mph?
