Old Aug 20, 2006 | 08:24 PM
STKN1STGEAR's Avatar
Default ????????????
ok
What does it mean when blue smoke comes out the exhast at startup?
If I remember correctly blue is oil and white is antifreeze?
Old Aug 20, 2006 | 08:49 PM
STALL UP's Avatar
it is probably your valve seals leaking oil onto the piston while the car sits and burns it when you start it.
Old Aug 20, 2006 | 09:59 PM
Yes I think that could be happening, but I think maybe that I burned a piston.
My vac went from 20 to 15, the motor isn't steady at low RPM. I was in the middle of tunning a new supercharger when this happened. when I take the oil fill cap off
i feel puffs of air coming out. I have EFILive can I use this to tell what is going on?
Old Aug 20, 2006 | 10:00 PM
If i post my tune can someone look at it and tell me if
i did something wrong?
Old Aug 20, 2006 | 10:22 PM
OK
I have a stock 99 SS Camero w/ vortec super charger and borland exhaust.
If someone would look at my tune and tell me if it could have caused a problem that would be great.
I'll have to email it to you, as it is to large to upload.
Thanks
Old Aug 21, 2006 | 05:33 PM
LugNutLS1's Avatar
When I had a turbo, I blew the oil fill cap right off and burned a ton of oil when I trashed a ringland on piston. Were you under boost or heavy detonation when this problem occured?
Old Aug 21, 2006 | 06:27 PM
We had just done a scan run with heavy boost, on / off the gas, high speed, low speed. the car never overheated or even got hot. it just blews a lot of smoke.
The car has plenty of power.
is it possible that I blew a seal in the Blower and it is pumping oil down the intake?
Old Aug 22, 2006 | 10:58 AM
So what do you think?
Old Aug 22, 2006 | 11:49 AM
CrazyChris's Avatar
If you are worried about a piston being toast, do a leak down test and it will tell the story. Also if you took screen shots of your timing or whatever tables are in question you will get more replies. Are you logging with a wideband?
Old Aug 22, 2006 | 11:56 AM
I plan on doing a leak down this weekend. I'll see if I can get some screen shots. yes I am logging with a WBO2
Old Aug 22, 2006 | 02:27 PM
kbracing96's Avatar
I'm pretty sure you broke a piston. If you have oil smoke coming out the exhaust and a lot of blow by coming out the oil cap when you take it off, then you have a piston that's not sealing at all. Happens ALOT on FI motors when you get to much timing and not enought fuel. A quick compression test will tell you a lot. Start with number 7, it's usually the first to go.
Old Aug 22, 2006 | 05:41 PM
That was what I am afraid of. Do you think I could just replace the bad piston or do you think I need to rebuild the engine? I don't want the metal particals foating around in there.
Old Aug 22, 2006 | 05:43 PM
I thought that the AFR was supposed to be at around 14.7:1?
Old Aug 23, 2006 | 03:23 PM
kbracing96's Avatar
While you have it apart, might as well beef it up with some forged pistons and some new bearings. Going to need to be rebalanced with the new pistons. 14.7 is fine for the part throttle cruse areas, but WOT on a FI motor NEEDS to be around 11.5 to be safe. For timing, 16-18* WOT should be pretty safe also.
Old Aug 23, 2006 | 03:25 PM
kbracing96's Avatar
If you want me to take a look at your log and tune, sent me a PM and I'll give a email to sent them too. (I have EFILive)
Old Aug 23, 2006 | 04:29 PM
jimmyblue's Avatar
Moderator
Worn exhaust valve guides / seals will make
a brief blue smoke on start only, with no sign
of internal problems (still can have good
compression, though generally this level of
wear is not going to just be seen in the
guides and not other rubbing elements).
If leakdown / compression tests aren't a
smoking gun (heh) then you can just live
with it until you foul out cats / O2s from
all the oil & metallics.
Old Aug 23, 2006 | 06:16 PM
LugNutLS1's Avatar
If you broke a piston like I did, you definitely notice power loss. Plugs will give you 1st indication where to start with compression testing. FYI it was #7 to no surprise in mine. If you want to stay boosted go with forged internals while motors out to save yourself a repetitive PITA.
Old Aug 23, 2006 | 10:22 PM
Black02SS's Avatar
This is partially why you have the problem that you do. Here is a screen shot of his open loop fuel air table. He PE is set to 14.63.
Old Aug 23, 2006 | 10:30 PM
Black02SS's Avatar
Here is another pic of a log at WOT. You can see what is commanded and what is actual as well as the KR.
Old Aug 23, 2006 | 10:38 PM
Doc's Avatar
Doc
Yiiiikkes
