Narrowband O2 sensor wiring?
Old Aug 24, 2006 | 09:17 AM
rosulekg's Avatar
Default Narrowband O2 sensor wiring?
Hi;
I am measuring only .86v max from my Dynotune digital gauge where it should be around .94v initially because my Z06 is turbo tuned for a dyno initial 12.9AFR to 11.1AFR max.
Could the wire I ran to the O2 be dropping the Voltage that much?
Thanks!
Old Aug 24, 2006 | 09:51 AM
dynocar's Avatar
Whether a narrow band reads .86 Vs .94 does not indicate what your A/F is, just that you are more rich then 14.7. At that extreme of the narrow band's range, a different one probably would read differently. Don't try to tune a turbo car with a narrow band.
Old Aug 24, 2006 | 10:04 AM
rosulekg's Avatar
Thanks, I'm not tuning the car but it gets .83v at part throttle and .86 max at wide open throttle. That doesn't tell me much! Dynotune claims the gauge will read a narrow band and even can tune with it.
It makes sense that for the stock intent of the 02 the limitation that I am seeing is perfectly exceptable.
Old Aug 24, 2006 | 10:13 AM
SSpdDmon's Avatar
That reading means it could possibly be running lean (ie in the 13.5:1~14.0:1 AFR range). You need to have your AFR read by a WBO2 in order to get an accurate reading. I have typically seen cars running the right AFR with headers in the .93x~.94x range on the NBO2 voltages. I agree with the above saying they're not accurate for tuning purposes. But, I don't think they are so inaccurate that they can't detect a general lean condition at WOT. Find someone who can plug into your header bung and get a good reading....
Old Aug 24, 2006 | 10:26 AM
rosulekg's Avatar
I had my car dyno'd a few weeks ago and the AFR was hitting 10.8 out of the tail pipe, and I'm sure it would have blown up by now if it was that lean so I ask again does anyone think my thin wiring could be dropping the voltage?
Old Aug 24, 2006 | 10:34 AM
muncie21's Avatar
I doubt wire impedance would eat up that much voltage, considering the short distance between the O2 and the cockpit of the car. I'd be more inclined to check for a ground offset issue.
Old Aug 24, 2006 | 10:40 AM
rosulekg's Avatar
Thanks, I'll run the ground to a better Location! I used the accessory ground.
Old Aug 24, 2006 | 12:47 PM
dynocar's Avatar
If you were 10.8 A/F (rich) and your O2 is approx .90V (rich) everything is agreeing. What am I missing, outside of the 10.8 being too rich, I don't see a problem???.
Old Aug 24, 2006 | 02:49 PM
rosulekg's Avatar
My car is a turbo and should have blown up if I was running to there chart!
Check it out:
http://www.dynotunenitrous.com/store...p?idproduct=15
I'm just trying to find out if I am missing something or is this thing going to have to be Normally Aspirated only!!
Old Aug 24, 2006 | 05:51 PM
dynocar's Avatar
Thanks, I follow you now, thought I've seen everything.
Old Aug 24, 2006 | 06:04 PM
jimmyblue's Avatar
Moderator
The O2 sensor PCM inputs draw negligible current so you
are not likely dropping any voltage along the wire regardless
of wire gauge. The sensor output in the rich region (> 0.7V)
varies more with temp than with mixture. Even same car,
same settings, thermal history alone will jack you around
a lot in voltage, to the point that it's no better than maybe
0.5 AFR accurate even if you had a good NB:WB correlation
for your unique plumbing and thermals.
Old Aug 24, 2006 | 09:58 PM
rosulekg's Avatar
Thanks, i just got a .9v out of it at partial throttle, and for some reason I feel better. My tuner told me this would happen, but I wanted something and I'm going to get a tune and more boost next year. Anyway, I put an DPST switch in to track both the sensors so I can at least be following my normal fuel, Thanks again!
