idle issues... PCM is freakin out
jay, jeff and i decided on trying to fix my idleing issues....well....i definately have issues....
heres the problem...
reset the TPS sensor
turn the Key to run position but had the motor off.....and the TPS reads 0%
start the motor and it now reads 2%....thats just by starting the car...so the car is in part throttle tables now....idles like ****....the idle hunts around
now...we got the car rolling bout 20 mph on the dyno and stopped it and the tps went back to 0%....car idles fine!
we switched TPS's...same problem....
what yall think it is...PCM??
i still dont get why when the car is off it reads 0 but when its started its 2....but if i roll the car 50 feet and stop its at 0.....
here are the codes i got after swapping pcms...
ok...swapped tb and pcm....NOTHING...same ****....
i got a whole bunch of old codes and an unknown
C0266 - Unknown (Current)
U1000 - Class 2 Communication Malfunction (History)
B0026 - LF/Driver Frontal Deployment Loop (Single Stage or Stage 1) Open (History) (Current) (Immature)
U1000 - Class 2 Communication Malfunction (History) (Immature)
C0240 - Unknown (History)
B1001 - Option Configuration Error (History) (Immature)
U1301 - Class 2 Short to Battery (History) (Immature)
U1016 - Loss of Class 2 Communication with VCM (History) (Immature)
U1040 - Loss of Class 2 Communications with ABS (History) (Immature)
U1096 - Loss of Communications with IPC (History) (Immature)
Continuous Tests
Misfire: Complete
Fuel System: Complete
Comprehensive Component: Complete
Once Per Trip Tests
Catalyst: Complete
Heated Catalyst: n/a
Evaporative System: Incomplete
Secondary Air System: Complete
A/C System Refrigerant: n/a
Oxygen Sensor: Incomplete
Oxygen Sensor Heater: Incomplete
EGR System: Complete
when i start the car it jumps to 2%....
i drive the car 100 yards and come to a stop and it reads 0%
