EFI live users
Old Sep 3, 2006 | 01:04 AM
redhotz28's Avatar
Default EFI live users
I just recently had a budy of mine tune my car with efi live. i think all is good except there is a bucking when i am at low idle speeds and mph in 3 and 4. i have a tci 3000 stall and i was wondering if there is any way to tune that out? Also during start up, it seems as if the idle is searching. what i mean is it goes up and down and some times dies, when it is low and you put it in gear it will die also. any help would be appreciated. -vince
Old Sep 3, 2006 | 01:38 AM
TAQuickness's Avatar
Would help to get a log or two to narrow down the possibilities. But in short, yes, most of the ill side effects your having can be tuned out.
Old Sep 3, 2006 | 10:10 AM
SSpdDmon's Avatar
What's all done to the car?
Old Sep 3, 2006 | 10:56 AM
redhotz28's Avatar
h/c, fast 90/90,tci 3000 stall 3.73 gears, and then my friend tuned it to speed density. would any of you guys know where to start at to try to solve the problem.
Old Sep 3, 2006 | 11:58 AM
foff667's Avatar
LS1TECH Sponsor
I dont think you'll be able to find just one answer...in most cases with a4 cars I just find where it starts to buck and alter the tc lock/unlock tables.
Old Sep 3, 2006 | 03:52 PM
Redline-Motorsports's Avatar
Is there a cam in the car? I don't mean the stock one.........
Old Sep 4, 2006 | 02:47 PM
redhotz28's Avatar
yes, its a 228/232,498/502 lift and 114+2 lsa
Old Sep 4, 2006 | 03:32 PM
foff667's Avatar
LS1TECH Sponsor
that would be a very odd cam...are you sure those specs are correct?
Old Sep 4, 2006 | 03:36 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Could be the torque converter locking up at too low an rpm.
Old Sep 4, 2006 | 04:21 PM
Slowhawk's Avatar
LS1Tech Sponsor
It can be fixed for the most part.If it's a 98 it will be harder.Also TCI converters can be a bitch sometimes.
Old Sep 4, 2006 | 05:19 PM
Black02SS's Avatar
I'm with you on this.
Old Sep 10, 2006 | 11:47 PM
redhotz28's Avatar
the cam is a custom grind designed by tony mamo at AFR. do any of you guys have any suggestions on how to tune it out?
Old Sep 10, 2006 | 11:51 PM
Black02SS's Avatar
I can't picture Tony specing a cam like that. I can see it beiing a 228/232 .588/.595 114+2 You should have had a cam card from comp when he shipped it to you. I would double check that and go from there.
Old Sep 11, 2006 | 05:21 PM
Doc's Avatar
Doc
Could be timing, converter lock/unlock. SD tune is going to need attention, I hope this is a really good friend.
