Will not start
Old Sep 8, 2006 | 11:37 AM
dynosmith's Avatar
Default Problem starting - no spark
I have spent a few hours now reading other related posts and have not seen my specific symtoms listed so I thought I would post my problem and see if anyone has any suggestions...
I am installing an 04 GTO LS1 in my 68 vette, I am using the 04 GTO wiring harness without the BCM. I have EFILive and used it to remove VATS. I have the engine cranking and I can smell fuel but I have no spark. I have verified that the cam sensor and crank sensor are plugged in and EFI Scanner reads values for both sensors. The strange symptom I have is that the car will only crank for a few seconds and then stops. I have to turn the key off and then back to crank for it to work??
Any ideas?
Thanks in advance!
Last edited by dynosmith; Sep 8, 2006 at 04:45 PM. Reason: Title change for better searching for other users
Old Sep 11, 2006 | 09:54 AM
dynosmith's Avatar
Thanks anyway, I found the issue - it was a faulty Park/Neutral switch connection. I also had a power wire missing for the coil packs so it fired up for the first time now!!
